rwd_mayhem wrote:on the plate on the firewall, it says trans/axle then a code of some type, dont know if thats what you want though.
l1ttle_d3vil wrote:as far as I know the only major difference between ke3# series diff heads was with the axles/diff heads. if you get replacement axles and diff head from the one car you should be sweet leaving your current diff housing in there.
ive got a diff head and axles at my dads, already all packed up ready to be shipped (was going to sell them to another guy but he changed his mind). just if you get stuck...
otherwise ive got another ke35 diff housing with just the axles here...not sure what model they're out of though but if anyone can tell me what the actual differences are between the different axles I can do some measuring for you to see if mine match...
