4AGTE problems PLEASE HELP!!!**Edited error codes**
Postby tHE _mEXICAN » Wed Apr 18, 2007 2:42 am
Ive recently converted my ae101 4agze to turbo with Ht18 turbo blue top cams front mount ext. waste gate BOV. I'm using a small port 4age inlet mani, alt PS pump
Now since i've had it running it never seems to have much pull at all.
So yesterday i finally found out on how to a diagnostic check and it came up with the following errors:
24 Intake air Temp Sensor Signal
Diagnosis
* Open or short circuit in intake air temp sensor signal (THA).
Trouble Area
* Intake air temp sensor circuit
* ECU
25 Air-Fuel Ratio Lean Malfunction
Diagnosis
* When air-fuel ratio feedback compensation value or adaptive control value continues at the upper(lean) or lower(rich) limit renewed for a certain period of time.
* When air-fuel ration feedback compensation value or adaptive control value feedback frequency is abnormally high during feedback condition.
* When marked variation is detected in engine revolutions for each cylinder during idle switch on and feedback condition.
*O2 sensor output in less than 0.45 volts for at least 90 seconds when O2 sensor is warmed and 1500 rpm or above
Trouble Area
*open injector circuit
*lack of fuel pressure
*Ignition system
*Vacuum sensor
*O2 sensor
*ECU
31 Vacuum sensor
*No signal at Vacuum sensor (PIM)
Trouble Area
*Vacuum sensor to ECU
43 Starter Signal
Diagnosis
* No "STA" signal to ECU until engine speed reaches 800RPM with vehicle not moving.
Trouble Area
* Ignition switch circuit.
* Ignition switch
* ECU
The weird thing is that its seems to be running rich as you can smell it and my AF guage never reads lean and is constantly in the rich range when your foot is to the floor.
My rail pressure is set to 35psi at idle on my after market risng rate FPR and every thing seems to be in order.
I thought it could with a tune but have reads heaps on here that it should still go hard without one using the factory maps etc.
Timing is set to 5 deg and i also installed an SAFC-I once it was turbo
I've noticed that when the car is off it usually reads vacuum on the SAFC and has once read boost. does this mean my map sensor is buggered?
Also from time to time it miss's quite badly and idle ranges from 600-1200rpm.
I've fiddled with it heaps and talked to quite a few people but cant seem to get it going good just seems to go like an N/A one really
Can anyone help me out please and point me in the right direction
RIDES:
73' KE25 SR Coupe (LONG TERM PROJECT)
Soon to be 4AGTE monster powered
tHE _mEXICAN
Postby big_boy » Wed Apr 18, 2007 1:14 pm
am i reading this corectly that its a 7M-GTE AFM you useing if so
you do relise there were 3 different pin confrigations all with the same plug?
also both your problams seam to be in the AFM so maby check that plug & wireing
for sale EE90
big_boy
Postby Crucible » Wed Apr 18, 2007 1:41 pm
has the air temp sensor been removed from the charger manifold and put into your piping, plugged in?, it will go into limp if not.
Is the cam timing right?, how much vacuum do you have at idle? or where they already in before the conversion?
Crucible
Real Life Mechanic
Postby tHE _mEXICAN » Wed Apr 18, 2007 2:16 pm
I was talking to my mate whom helped me with the conversion last night. And i don't think we have.
What does it look like? as we looked on this guys ae101 trueno but could not spot it, we think its the white box thingy just before throttle body is this right?
And i'm pretty sure timing set but i guess ill recheck it just incase
Thanks
RIDES:
tHE _mEXICAN
Postby Distrb » Wed Apr 18, 2007 3:35 pm
Do excuse me for potentially querying the obvious...
If it is 4agze engine from Ae101 gtz, it should not have an AFM at all, as they're map sensored.
or are you actually using a 4agze from an ae92 gtz or mr2 that requires an AFM?
Distrb
Regular Poster
Postby tHE _mEXICAN » Wed Apr 18, 2007 5:36 pm
big_boy wrote:am i reading this corectly that its a 7M-GTE AFM you useing if so
Ahh no i'n not using the 7M AFM at all its the error codes on the FAQ tech on this forums that says those codes. I'm puzzled as to why it's giving me this code
True-No-Turbo wrote:Is the cam timing right?, how much vacuum do you have at idle? or where they already in before the conversion?
When it runs good as in not missing usually bout 20-22InHg or what ever the units are. I put the cams in when i turboed it. Vacuum seems to be the same
RIDES:
tHE _mEXICAN
Postby ChaosAD » Wed Apr 18, 2007 6:52 pm
When you fabricated the turbo manifold where did you mount the oxygen sensor?
And as True-no-turbo said, do you have the intake air temp sensor hooked up? The redtop manifold should have one on it, I guess you could just swap it for the gze one.
ChaosAD
Re: 4AGTE problems PLEASE HELP!!!
Postby matt dunn » Wed Apr 18, 2007 8:20 pm
tHE _mEXICAN wrote:My rail pressure is set to 35psi at idle on my after market risng rate FPR and every thing seems to be in order.
is that with or without the vacuum connected?
Postby tHE _mEXICAN » Thu Apr 19, 2007 12:29 am
matt dunn wrote:is that with or without the vacuum connected?
Thats with the vacuum connected should i set it to 35 without it connected?
ChaosAD wrote:When you fabricated the turbo manifold where did you mount the oxygen sensor?
I put it about 100mm back from the original position it sits just about where the front sway bar is. Would this cause any problem would it?
RIDES:
tHE _mEXICAN
Postby matt dunn » Thu Apr 19, 2007 1:07 am
Yes
Why not use the standard pressure reg?
Postby tHE _mEXICAN » Thu Apr 19, 2007 1:24 am
matt dunn wrote:Yes
Oh i see i should hav known that. Don't have standard reg as it came with after market when i bought the car
Thanks mate
RIDES:
tHE _mEXICAN
Postby TRD_ZERO » Fri Apr 20, 2007 6:50 pm
HEy man I met you at taka the other nite for johns going away shindig. Still having trouble with the wagon i see. Well all the best and ill be seeing it around.
TRD_ZERO
Postby tHE _mEXICAN » Fri Apr 20, 2007 8:23 pm
hey man, i remember you, yea still having trouble but i hope fixing the temp sensor will sort it. Ill be doing it this wknd so only time will tell.
RIDES:
tHE _mEXICAN
Postby TRD_ZERO » Sat Apr 21, 2007 12:28 pm
Yeah man hope you get it sorted this weekend dnt forget to maybe check with the factory fuel reg as the aftermarket one might be playing up as mentioned.
TRD_ZERO
Postby tHE _mEXICAN » Sat Apr 21, 2007 4:00 pm
TRD_ZERO wrote:Yeah man hope you get it sorted this weekend dnt forget to maybe check with the factory fuel reg as the aftermarket one might be playing up as mentioned.
Think i sorted that, i didn't know you had to set it to 35psi with the vacuum unplugged. Seems to run alot leaner now but not to lean.
Can someone show me a pic of the air temp sensor please, i don't think i ever had one. The only thing i can find is this white unit on the side of throttle body which has a spinning mechanism on it, unsure as to what this does tho.
RIDES:
tHE _mEXICAN
Postby tHE _mEXICAN » Wed May 02, 2007 1:46 am
Can anybody tell me if this is the intake air temp sensor?
RIDES:
tHE _mEXICAN
Postby matt dunn » Wed May 02, 2007 2:04 am
tHE _mEXICAN wrote:Can anybody tell me if this is the intake air temp sensor?
yes on map model only.
afm models have it in the afm.
