big_boy wrote:am i reading this corectly that its a 7M-GTE AFM you useing if so
you do relise there were 3 different pin confrigations all with the same plug?
also both your problams seam to be in the AFM so maby check that plug & wireing
When it runs good as in not missing usually bout 20-22InHg or what ever the units are. I put the cams in when i turboed it. Vacuum seems to be the sameTrue-No-Turbo wrote:Is the cam timing right?, how much vacuum do you have at idle? or where they already in before the conversion?
tHE _mEXICAN wrote:My rail pressure is set to 35psi at idle on my after market risng rate FPR and every thing seems to be in order.
matt dunn wrote:is that with or without the vacuum connected?
ChaosAD wrote:When you fabricated the turbo manifold where did you mount the oxygen sensor?
tHE _mEXICAN wrote:matt dunn wrote:is that with or without the vacuum connected?
Thats with the vacuum connected should i set it to 35 without it connected?
matt dunn wrote:Yes
Why not use the standard pressure reg?
TRD_ZERO wrote:Yeah man hope you get it sorted this weekend dnt forget to maybe check with the factory fuel reg as the aftermarket one might be playing up as mentioned.
tHE _mEXICAN wrote:Can anybody tell me if this is the intake air temp sensor?
