3sgte supra
3sgte supra
Postby bobbzr » Wed Apr 25, 2007 9:51 pm
just woundering out of curosity does any one no whats involved in puting a 3sgte in a jz80?
bobbzr
Postby Adamal » Wed Apr 25, 2007 10:00 pm
Ok, I doubt you have enough money to make it a worthwhile conversion.
Unless you're planning on stripping it out, caging it, and pretty much making it a track only car, theres no point.
Torque comes on late compare to the 2JZ, and the JZA80 has a lot to move...
Postby KinLoud » Wed Apr 25, 2007 10:27 pm
Ha - don't worry about Adamal's positive spin too much...
There have been some very successful 3sgte powered supras racing in Japan in the past. Going the 4 cylinder 2 litre way worked to their advantage due to rules and/or car balance.
Just so we can help you, please answer a couple of questions.
Are you wanting a race, street, show car?
Do you have a 3sgte lying around doing nothing or will you have to build one up?
The motor currently in the JZA80 is... Dead, NA, Heavy, Boring?
Basic requirements to put 3sgte into JZA80:
- JZA80
- 3sgte, loom and factory/aftermarket computer (depends if there is room for factory distributor against the firewall)
- Manual gearbox (i presume?) with suitable bellhousing
- custom exhaust manifold so turbo doesn't hit the rwd starter motor position.
- custom engine mounts
- custom cooling pipes/hoses/radiator?
- custom driveshaft
- intercooler and piping
- skill to do most or all of the above yourself OR
- loads of $
Hope this sort of helps to guide you.
Ken
Ham
021 408 863
Postby Truenotch » Wed Apr 25, 2007 10:31 pm
Should be able to get an S-W bell housing from somewhere (Came out factory in some coronas?) which would sort the gearbox....
Truenotch
Postby big_boy » Wed Apr 25, 2007 11:54 pm
Truenotch wrote:Should be able to get an S-W bell housing from somewhere (Came out factory in some coronas?) which would sort the gearbox....
JZA80 are R154 or V160 arnt they
for sale EE90
big_boy
Postby Mr.Phreak » Thu Apr 26, 2007 12:13 am
Or W58 for the NA's I thought
Mr.Phreak
Postby big_boy » Thu Apr 26, 2007 12:17 am
looks like your right used right thro intill 1998 on the NA ones
for sale EE90
big_boy
Postby the fallen303 » Thu Apr 26, 2007 9:31 am
aren't the 3sgte's in the jza80's in japan race only engines, and had a SHITLOAD of money spent on them? i'd say the amount of money for someone to make a 3sgte outperform a 2jz in the supra would be a lot! you'd loose a lot of torque from the lower capacity, and the amount of boost you'd have to run to get the power up to reasonable you'd have to do a serious build on the 3s. just doens't seem worth the hassle in a semi/street car. spend half as much on a good turbo/i/c setup on the 2j and you'll hit 500hp easy, don't see that happening on a 3s quickly/cheaply.
true house of JZ
Stay true to the origin
the fallen303
Postby Mr Revhead » Thu Apr 26, 2007 10:11 am
as pointed out the "3sgt" was used in the supras in the super gt series in japan for reasons of weight.
it wasnt a 3sgte as found in sw20s etc.
so unless your trying to make a supra fit into a 2 ltr class then it really isnt the best option
you need to spend a LOT on weight reduction and HP chasing....
Postby bobbzr » Thu Apr 26, 2007 6:21 pm
true true.il just use my black top 20v then :)
bobbzr
Postby Chickenman » Thu Apr 26, 2007 6:59 pm
The chassis couldn't handle the torque bro 8O
Baby Jesus
Chickenman
I Am The Walrus!
Postby bobbzr » Thu Apr 26, 2007 7:00 pm
yea didnt think it would a it makes like 45000hp
bobbzr
