by Rob_GTZ » Fri May 25, 2007 12:14 am
Adjusties are a waste of time unless you are going to use them for their intended purpose. If you just want to go Low Low, get a measuring tape, figure out how much lower you want to be, then get springs compressed, & if required get shocks machined to suit. Easy & Cheap. Spring compressing is about $20-$30 a spring, shock shortening retails roughly $40-$60 each.
