adjustable suspension for 97 carib bz-t
Postby Matty104 » Wed May 23, 2007 8:38 pm
does anyone no the best and more cost effective setup for adjustables in my wagon??
Matty104
Postby bluemaumau » Wed May 23, 2007 8:40 pm
probley a tech question mate.
are they superstraut?
if not bazda gets them in.
and 41 selld daiyama, which i have and look pretty good, may need to be modified to fit ae111 however
Postby Matty104 » Wed May 23, 2007 9:02 pm
yea sorry mate new to this place and dont no how 2 change it or anything yet, got any links i could go 2? cheers, oh and its non super strut
Matty104
Postby KinLoud » Wed May 23, 2007 9:09 pm
Welcome to toyspeed.
Do you think you would like new or second hand?
You can often get second hand setups for $500 to $1000
New - be cautious about buying D2 adjustables
Talk to Bazda as he is doing a group buy or something - look here viewtopic.php?t=55241&highlight=
Ken
Ham
021 408 863
Postby strx7 » Wed May 23, 2007 9:15 pm
is it 4wd?
Postby bluemaumau » Wed May 23, 2007 9:17 pm
bzt is blacktop correct? if so can you get them in 4wd, $&#$% that would be pretty wicked to turbo!
Postby Matty104 » Wed May 23, 2007 9:58 pm
[quote="strx7"]is it 4wd?[/quote],
Na m8 fwd, needs 2 be 4wd tho, cant keep it stuck down even with goodyear eagle f1's
Matty104
Postby Matty104 » Wed May 23, 2007 10:00 pm
bluemaumau , yes thats correct, blacktop 20v
Matty104
Postby Rob_GTZ » Fri May 25, 2007 12:14 am
Adjusties are a waste of time unless you are going to use them for their intended purpose. If you just want to go Low Low, get a measuring tape, figure out how much lower you want to be, then get springs compressed, & if required get shocks machined to suit. Easy & Cheap. Spring compressing is about $20-$30 a spring, shock shortening retails roughly $40-$60 each.
Rob_GTZ
Postby Rob_GTZ » Fri May 25, 2007 12:25 am
Actually on second thoughts, just put it on Bags.
Rob_GTZ
