is this normal?
is this normal?
Postby pjay » Fri May 25, 2007 12:59 pm
I drive a 92 gtz levin.
when i launch or accelerate hard my steering wheel pulls HARD to the right?
is most of my power being transferred through the one wheel?
is this normal? if not, what is it and how can i fix it?
Thanks
pjay
Postby pc » Fri May 25, 2007 1:29 pm
Do you have the same compound tyres on the front. Is your wheel alignment, toe/camber etc correct?
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby pjay » Fri May 25, 2007 2:18 pm
yes both tyres are new, same camber, everything is normal. thr drivers cv is on its way out.. could that be it?
pjay
Postby sergei » Fri May 25, 2007 2:37 pm
Check the driveshaft hanger bearing... and recheck wheel alighnment.
Postby pjay » Fri May 25, 2007 2:49 pm
driveshaft hanger bearing?
pjay
Postby pjay » Fri May 25, 2007 2:50 pm
*double post.. how noob
pjay
Postby sergei » Fri May 25, 2007 3:22 pm
right drive shaft is a 2 piece shaft, gearbox side piece hangs of the block on the bearing (just before inner CV-joint). you can check if the bearing is ok by grabbing the inner shaft and trying to wonble it arround.
The reasoning behid 2 piece shaft design is to reduce torque steer (by making both of the outer shafts, which are on the angle, equal). Correct me if I am wrong ;).
Postby TRD_ZERO » Fri May 25, 2007 8:08 pm
OK i got this all the time in my mazda turbo isnt it just torque steering?? No lsd making one wheel spin when boost kicks in and turning that wheel only, pulling the car to that side. Hey i have no idea just taking a guess
TRD_ZERO
Postby AceSniper » Fri May 25, 2007 8:21 pm
if its non lsd and its torque steer it would prolly pull to the left as the left axel is closer making it easyer to put more power there (what happend on c56 anyway)
AceSniper
Postby KinLoud » Fri May 25, 2007 9:32 pm
Almost certainly you have worn joints in your superstrut suspension.
Email Mr Revhead and he will do you a good price on toyota genuine replacement parts - do not buy remanufactured or aftermarket superstrut parts as they don't last.
Ken
Ham
021 408 863
Postby Mr Revhead » Fri May 25, 2007 9:39 pm
only thing is..... ae92 = no S/S :wink:
Postby KinLoud » Fri May 25, 2007 10:08 pm
i'm figuring 1992 GTZ... I hope!
Ken
Ham
021 408 863
Postby Mr Revhead » Fri May 25, 2007 10:11 pm
:lol: oh yeah....
in that case S/S is a prime suspect.....
does it pull under braking?
Postby pjay » Sun May 27, 2007 12:06 am
Mr Revhead wrote::lol: oh yeah....
only pulls when accelerating. itsa 92 gtz ae101. how much for parts? im needing rear shocks also, as well as drivers cv joint. pm me a price? thanks!
pjay
Postby Bling » Sun May 27, 2007 11:14 am
viewtopic.php?t=44317 go there, do that.
Postby pjay » Tue May 29, 2007 5:16 pm
thanks! will do now(ish)
pjay
Users browsing this forum: Yahoo [Bot] and 20 guests
