anyone know this:
will a rb20det from a 2wd skyline fit into a 4wd skyline.
am aware the sump is different
Mr Revhead wrote:will a rb20det from a 2wd skyline fit into a 4wd skyline.
chch34 wrote:I was lead to believe you cant install a r32 rb20 rwd motor into a gts4 as the sumps mounting points are different, but the gts4 engine has bolt holes in the block for both the 2wd sump and the 4wd sump....
RS13 wrote:Hmm.. I have definitely seen a GTS4 with a GTSt motor, perhaps they've modded the factory sump.. I'll have to ask.
GTS4 Sump on the gts-t. AFAIK the t sump not bolting to the 4 sump and the other way round is a myth. Either bolt together as it is a rb block after all.
Off topic, seeing that, i dont see how a 4x4 engine will fit in a 2wd?
