5mge and 7mge alternater the same?
Postby MrDori » Tue May 29, 2007 5:56 pm
yes or no?
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
Postby deaf_rattle » Tue May 29, 2007 6:31 pm
depends on which style
the 5mge had two types multi rib and twin v
the multi rib one can be swapped with a 7mge/gte one
If you are after a twin v type i have one for sale at the moment.
Postby MrDori » Tue May 29, 2007 6:36 pm
how much, ive got a whole 5mge motor thats all, ansd 7m alt has died
MrDori
Postby deaf_rattle » Tue May 29, 2007 6:39 pm
for you $40
is it the twin v type one you are after?
Postby MrDori » Tue May 29, 2007 6:54 pm
ah ill think about, what cars to the v type or what ever come on
MrDori
Postby deaf_rattle » Tue May 29, 2007 6:57 pm
early 5mge, so ma61 and mz10, i think cressidas come with different ones as do the later model ma61s
ga61s run different alternators again.
mteu alternators maybe the same as early 5mge, but not 100 percent on that.
Postby big_boy » Tue May 29, 2007 7:32 pm
MTEU have the same as early 5M but different there 55A not 65A
if your after a 7M or 5M (both types) i have 2 of each on the spairs shelf that im up for offers on the cresidas also came out with 2 types both are internal reg 7PK series but one is 85A & the other is 65A depending on factory specs of the car
also the 2 V alternators have a smaller sharft than most of the muilty ones (7PK) with the exception of the 60A 7PK
mountings are different on the 2V verses the 7PK
2V`s came in 40A,45A,55A,60A & 65A depending on car ect & are external reg
7PK`s came in 55A,60A,65A,80A,85A & 100A in some contreys never jappa or NZ tho & are internal reg
the 40A 2V`s came off the early 2WD hilux`s & will fit 18R
when swapping them arround rembour there is a different reg for each of the 2V external`s & the 45A has different pin outs to the other so you need to change the earth with 1 or the ault wires cant rembout witch 1 it is tho
also for the 2V ones 8R-C=40A 18R-C=45A 20R= (1975-79)40A opitnal 55A regs adjustbal (1980 same but no adjustment) 22R= (1981)40A opitnal 60A 22R(-E)= (1982-85) 55A or 60A 4M-E=55A or 60A 5M-E=60A or 65A 5M-GE=65A external or (84-86) 60A internal reg
all of the above fit in the same holes
for sale EE90
big_boy
