silvertop temp issue! & idle
Postby Luke28 » Tue May 29, 2007 9:01 pm
I didnt remove the aircon my self.. a mecanic done it.. the pump is still there its just disconected.. pretty sure its been running cold since i brought it.
Luke28
Postby Alex B » Tue May 29, 2007 9:05 pm
When the car is cold, the injectors have a longer duty cycle. And the mechanic didn't finish the job if the fans are always running.
Postby AceSniper » Tue May 29, 2007 9:24 pm
Id say its a 98% chance it needs a new thermo....
EVERY (quite afew) 20v's I have pulled the thermo from have been dated with the year built (never been replaced) an most are jammed open
AceSniper
Postby EVL20V » Tue May 29, 2007 9:32 pm
yea 1/2 way on gauge is normal running temp. once ive replaced the thermostat then will see if that fixes it :D
EVL20V
Postby Luke28 » Tue May 29, 2007 9:45 pm
If toyota is open on saturday ill pop down and buy a new thermo and replace the old one.. if it still runs cold then must have something to do with aircon i guess.. Will post up the outcome on the weekend if anyones interested..
Let us know if it fixes ur prob EVL20V..
Luke28
Postby AceSniper » Tue May 29, 2007 9:49 pm
even if the aircon fan is runing non stop the thermo would stop the water cycling when it drops below 82.
AceSniper
Postby Luke28 » Tue May 29, 2007 10:16 pm
both aircon fan and aircon radiator have been taken off.. its the radiator fan thats always going...
Luke28
Postby Alex B » Tue May 29, 2007 10:21 pm
Yea, you need to jump the pins where one of the pressure switches on the ac system were to stop that.
Postby AceSniper » Tue May 29, 2007 10:35 pm
the plug below the ignitor/coil runs onto a switch in the a/c alloy line
AceSniper
Postby Luke28 » Tue May 29, 2007 10:46 pm
ohh... im with ya now :lol: which pins do i need to jump? :?
Luke28
Postby sergei » Wed May 30, 2007 12:25 am
try either opposite two, maximum 2 tries to get right ones ;).
Removing AC will not make car cooler (as in bad thermostat symptom) full stop. The only thing what it affects is that bloody fan. AC idle up solenoid normally is not activated so it should not affect idle. If in doubt you can disconnected it is located behind air intake pipe (the one which is between AFM and inlet manifold), just pull the plug of the solenoid and see if it makes the difference (it should not).
Postby Luke28 » Sun Jun 03, 2007 5:36 pm
Well i poped a new thermostat in today and temp goes up just below half :D
Just gota sort the fan so it doesnt run all the time and all sorted.. but that can wait cause it wont stop bloody raining :x
Luke28
Postby EVL20V » Sun Jun 03, 2007 7:53 pm
installed new thermostat, instantly noticed cold idle had dropped and was more reasonable :wink: THEN adjusted timing and had to retard it about 8degrees 8O and shes mint now :lol:
EVL20V
