by atmosports » Sat Dec 15, 2007 3:57 pm
A knocklink is better than nothing, a knockblock with a headset is ok, but what you really what is a decent det headset like Link used to make, or like we make, which is probably similar to Qikstarlie's one. HKS etc make them as well, but everyone that has used one like ours throughs the HKS etc ones away. Anywhere on the block is ok & is most cases you can also bolt onto the head as well, it really depends on what your listening for as we use ours for stuff other than detonation. If you've got a good setup you should be able to hear the injectors, oil draining back into the sump etc once you know what your listening for.
Definately use a bosch style donut sensor, use sheilded cable with a new injector plug on it to connect to the sensor etc. Don't use the stock sensor & also I'd be hesitant to use any form of closed boost knock control as most of what I've seen on aftermarket ecu's ends up tuning a nice driving car into an overly rich pig with no ignition timing.
