7mge main crank pulley not spinning
Postby MrDori » Sat Jun 02, 2007 3:06 pm
noticed a mad knocking noise, thought it was a big end bearing but the crank pulley is not spinning so not charging alt or spining water pump.
What would this be? does it go into a keyway?
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
Postby slighty_sykotic » Sat Jun 02, 2007 3:58 pm
Man that must be making some noise 8O
And yeah, i'd say u've killed the keyway.
Take it off and have a look, and see if you can repair it with chemiweld or something (easy option).
--Sykotic
slighty_sykotic
Postby MacrosSiR » Sat Jun 02, 2007 4:12 pm
slighty_sykotic wrote:Take it off and have a look, and see if you can repair it with chemiweld or something (easy option).
Would be better to take it to an engine reconditioners who repair crank snouts without taking the engine out.
MacrosSiR
Postby slighty_sykotic » Sat Jun 02, 2007 4:16 pm
Yup, defintly true. But if its not 2 bad, like maybe the key broke into pieces and didnt do much damage, you could get away with putting a new key in, and a bit of something around it to take up the slack.
Just it depends on the car and how rough/cheap you want it to be.
Because if the bolt and everything is done up tight, alot of the strain should be taken by the fricton, not the actual keyway.
slighty_sykotic
Postby evil_si » Sat Jun 02, 2007 5:21 pm
or how about the crank has broken, try pulling on the pulley, see how much movement there is
evil_si
Postby MacrosSiR » Sat Jun 02, 2007 5:22 pm
slighty_sykotic wrote:Because if the bolt and everything is done up tight, alot of the strain should be taken by the fricton, not the actual keyway.
I wouldn't risk it.
MacrosSiR
Postby MrDori » Sat Jun 02, 2007 5:37 pm
pully is loose as a krd hooker.
Im not quite following what might be wrong?
MrDori
Postby Jason T » Sat Jun 02, 2007 6:31 pm
_________________
Taylor Automotive do crank keyway snout repairs in place
http://www.taylorautomotive.co.nz/services.htm
Fixing Toyota's since '87
Jason T
Postby MrDori » Sat Jun 02, 2007 7:48 pm
cool thanks, wander what sorta dollars we talking
MrDori
Postby MacrosSiR » Sat Jun 02, 2007 7:55 pm
ask for a quote
MacrosSiR
Postby matt dunn » Sun Jun 03, 2007 11:54 pm
Check the actual pulley first.
Have had a gfew vehicles in at work wher the actual V belt part fo the pulley is rubber mounted to the centre part that bolts to the crank,
and som when the rubber gives out the centre of the pulley will spin, but not the outside.
Easy to see if you just look with a torch while the engine is idleing.
Matt
