Calvin wrote:remove wheels and put on axle stands and then angle grind the threads off the hubs.. Aint going no where!!! lol
strx7 wrote:one has to wonder at the intelligence levels of people suggesting things to do with the starter motor or the battery, Ever heard of push/roll starting a car? you dont need either of those 2 items for that.
l1ttle_d3vil wrote:strx7 wrote:one has to wonder at the intelligence levels of people suggesting things to do with the starter motor or the battery, Ever heard of push/roll starting a car? you dont need either of those 2 items for that.
you don't need a battery to push start a car?![]()
Defective wrote:some do some dont.... some still need the circuit to be maintained even if the battery is as dead as a dodo...
Defective wrote:
try it on your car, start it up and disconnect the battery terminal and see what happens....
Zak wrote:You can't start a car with out a batt.
As with out power to start with the alt can't generate any and you'll get no where. It doesn't need much power, but it does need some.
