what can i do?
Luke28
what can i do?
Post by Luke28 »
What can i do under my bonnet quickly to stop my car from being started, hotwired or what ever?? going away and just thought it would be a good idea to lower the chance of it ''going for a drive'' without my permission 8O its a silvertop by the way
Post by frost »
take off any one of these items and store it in side the house.
leads, battery, coil, main efi fuse or engine fuse.
Burning Angel
Post by Burning Angel »
starter motor wires in a pretty obscure place on those engines. its the black one with a white stripe under the intake plenum. or all of those above
Luke28
Post by Luke28 »
Yer was thinking leads so yer thats prob the easiest so ill do that.
will let some fart bombs off inside the car too. HAHAH nah :lol:
RS13
Post by RS13 »
I took my ECU out, then put all the covers back on. :)
Calvin
Post by Calvin »
remove wheels and put on axle stands and then angle grind the threads off the hubs.. Aint going no where!!! lol
Jdawg
Post by Jdawg »
I would go with remove the wheels, that way any crims just move on, you won't have the window smashed , ignition broken before they find out it wont start
Quint
Post by Quint »
Open the glove box, and unplug the ecu. easy, simple and unless u knew cars you'd have no $&#$% idea.
Luke28
Post by Luke28 »
Calvin wrote:remove wheels and put on axle stands and then angle grind the threads off the hubs.. Aint going no where!!! lol
LOL.. nah dont think i will go that far!!
Imagine the look on someones face if they went out to there car in the morning to go to work and found there car like that!! 8O :evil:
jafa.and.proud
Post by jafa.and.proud »
Meh, just disconnect the battery, take it out, and take the terminal ring off the +ve wire :lol:
1997 Jaguar XJ on 20s
1993 Mitsi Mirage Cyborg
Ex - 85 Corolla GL (EE80)
Post by Alex B »
Take the lead off from the coil to the dizzy, easy as that. I dont think those run an internal dizzy.
Post by strx7 »
one has to wonder at the intelligence levels of people suggesting things to do with the starter motor or the battery, Ever heard of push/roll starting a car? you dont need either of those 2 items for that.
Post by l1ttle_d3vil »
strx7 wrote:one has to wonder at the intelligence levels of people suggesting things to do with the starter motor or the battery, Ever heard of push/roll starting a car? you dont need either of those 2 items for that.
you don't need a battery to push start a car? :?
i would say remove all the ht leads, take the ecu out of the car alltogether and remove a few fuses / relays etc.
Defective
Post by Defective »
some do some dont.... some still need the circuit to be maintained even if the battery is as dead as a dodo...
try it on your car, start it up and disconnect the battery terminal and see what happens....
Barks
Post by Barks »
Ha. Been there, done that. Tried it while I was trying to wire up the master kill switch on my race car. Car still runs.
To stop the car the white wire from the alternator to the back of the ignition barrel needs to be cut as well.
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music"
Kristian Wilson, Nintendo, Inc, 1989
Latest rides: 2004 Avensis Wagon, GT Avalanche 1.0, GT Avalanche 0.5, Marin Toscana CX
Defective wrote:some do some dont.... some still need the circuit to be maintained even if the battery is as dead as a dodo...
but no matter what, wouldn't you need the fuel pump etc to be running and have power going to it BEFORE you push start the car? how would the car start without fuel being pumped to the injectors?
might sound like a stupid question...but im stupid :roll: :lol:
AceSniper
Post by AceSniper »
D/c the batt as its good not to leave everything powered
unplug the ecu... you can doit with out removing it. or pull efi fuse in engine bay
If you have a alen key on hand pull the leads.... coil to dizzy you can just use a heavy wire taped in :lol: but no plug leads... you cant just use anything on 20v
slighty_sykotic
Post by slighty_sykotic »
I would be slightly careful about that, not sure how fast 20v alternators react to changes in it's load. Big change like removing the battery can cause the voltage to spike enough to hurt something (stereo most likely).
--Sykotic
Zak
Post by Zak »
You can't start a car with out a batt.
As with out power to start with the alt can't generate any and you'll get no where. It doesn't need much power, but it does need some.
slighty_sykotic
Zak wrote:You can't start a car with out a batt.
What? That reason doesnt make any sense at all.
(not saying that you can start a car without a battery, but your reason is interesting)
Explain to me why the alternator needs power to make power...
EDIT:
Wait, are you meaning the voltage up line that turns the alt on? If so, then yeah, ill agree with you, but only on cars that run that line. I know my 4k didnt, and my 4age in my mr2 didnt (hacked loom tho, it was meant to).
Last edited by slighty_sykotic on Sat Jun 09, 2007 4:05 pm, edited 1 time in total.
Post Reply
