soarer smoke
soarer smoke
Postby avinesh » Sat Jun 09, 2007 1:02 pm
hey guys my soarer smokes everytime i turn it on especially when its cold it doesnt smoke for a long time just one puff comes out when started an then it goes away it doesnt smoke on wide open throttle an even when accelerating it only smokes when started......the rev does go to almost 2000rpm when started but i dunno if its normal, the car is an auto 1jzgte twin turbo
avinesh
Postby Mr Revhead » Sat Jun 09, 2007 1:06 pm
smoke? or some water vapour?
Re: soarer smoke
Postby Jason T » Sat Jun 09, 2007 1:59 pm
avinesh wrote:hey guys my soarer smokes everytime i turn it on especially when its cold it doesnt smoke for a long time just one puff comes out when started an then it goes away it doesnt smoke on wide open throttle an even when accelerating it only smokes when started......the rev does go to almost 2000rpm when started but i dunno if its normal, the car is an auto 1jzgte twin turbo
Valve stem seals
2000 rpm start up is far from normal first place to start
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=FI&Page=23
Follow the flow charts to diagnose
Fixing Toyota's since '87
Jason T
Postby avinesh » Sat Jun 09, 2007 2:06 pm
Mr Revhead wrote:smoke? or some water vapour?
blue smoke just a puff an then it goes away an then when the engines all heated up you can rev it to redline an it wont smoke
avinesh
Postby Si » Sat Jun 09, 2007 2:41 pm
Does it smoke more or less after you park it on a slope?
Current: , '96 SubaruImpreza
Si
Postby gepsk8 » Sat Jun 09, 2007 3:12 pm
turbos on there way out?
gepsk8
Postby Silent Knight » Sat Jun 09, 2007 4:02 pm
It'll be the Valve Stem Seals. 1JZs are prone on have those wear out.
Silent Knight
Postby edwagon » Sat Jun 09, 2007 6:44 pm
Definantly stem seals for the smoke on startup.
And I have found the 1800rpm cold start typical of the jz's that ive owned, but thats only when DEAD cold and should drop to more like 1200rpm after about 60 seconds and then 900 after 2 mins- it drops very quickly.
Def not right if it idles at 2000rpm when even slightly warm tho!
The do sometimes have trouble with the IAC which is what controls this - might be worth taking it off and giving it a good clean if you think its not right
edwagon
Postby avinesh » Sun Jun 10, 2007 1:52 am
edwagon wrote:Definantly stem seals for the smoke on startup.
will the stem seals cause damage to the engine
avinesh
Postby edwagon » Sun Jun 10, 2007 4:14 pm
Well, the stem seals won't cause the engine to suddenly 'let go' and cause a breakdown.
Depending on how bad it is and what your future plans for the car are, you can leave the stem seals until you next have the engine out/install cams/turbo upgrade etc etc, but I would definantly look at getting them done at some point.
edwagon
Postby avinesh » Sun Jun 10, 2007 5:31 pm
ill get them sorted in 3 months
avinesh
