AE85.6 wrote:then was thinking i can wire the sensor, fan, power and earth to a relay which should then switch the fan on when it reaches the correct temp.
sounds good in theory but is this correct or would it work ?
gepsk8 wrote:it will kick in at say 102 and out 95, if that helps.
AE85.6 wrote:ill look for a 97-105 but from memory the closest i saw was 95-105
