Auto trans over filled with oil
Postby thegreatestben » Sat Jun 16, 2007 7:38 pm
I checked the oil level in my transmission of my Mark II (1jzge auto) and whoever filled it put way too much oil in. I've been driving it around and its seems ok, just had a leak. Which is probably it pissing out the breather.
Question is should I not be driving around like this. Oil is very clean/brand new looking. It came up well over the full mark on the dipstick.
thegreatestben
Postby Dell'Orto » Sat Jun 16, 2007 8:42 pm
Did you check it while running or stopped?
Postby AE82 FXGT » Sat Jun 16, 2007 10:37 pm
Yeah, often manufactors guild lines to check the ATF would be:
have the car at operating temp
leave the car running
cycle through all the gears (1,2,D etc to P)
check the atf dipping the dipstick quickly, but as far as it will go (to avoid splashes giving a false reading)
along those lines, but not sure if it would apply to your car.
AE82 FXGT
Postby thegreatestben » Sun Jun 17, 2007 2:25 am
Car had been run and was warm. Will double double check but I'm talking like 5 times over full here. Quite far up to have me unsure about it. Never had auto before but doesnt seem right.
Thanks for suggestions so far
thegreatestben
Postby Ae92typeX » Sun Jun 17, 2007 10:05 am
Perhaps go into your local garage to make sure you are checking correctly. if it is actually 5X more than it should have you will do damage...and autos cost more $$ to fix.
Ae92typeX
Postby Lloyd » Sun Jun 17, 2007 12:09 pm
tgb.mr2 wrote:Car had been run and was warm
Had been run when checked or was running when checked?
Postby thegreatestben » Sun Jun 17, 2007 12:58 pm
wasnt running. had been driving it.
are the above instructions the right way to check?
thegreatestben
Postby Dell'Orto » Sun Jun 17, 2007 1:15 pm
Yeah all the auto specialists I talked to said it had to be running when you check it, otherwise it looks like its mega overfull.
Postby tex » Sun Jun 17, 2007 1:30 pm
Check when running and up to temp. If it over fill it will $&#$% the trans. Or a good sign that the trans on the way out....
tex
Postby thegreatestben » Sun Jun 17, 2007 5:40 pm
Sounding like I've just checked it wrong as the car drives perfectly. and has done for the last month.
thegreatestben
Postby big_boy » Sun Jun 17, 2007 6:55 pm
assumeing its the same box as a toyota supra then they show way over full if checked when not running
check when running in netural & warm
for sale EE90
big_boy
Postby thegreatestben » Tue Jun 19, 2007 10:30 am
Yup same box as supra so I will assume that everything is ok!
Sold the car, going tonight.
thegreatestben
