Logan wrote:its not hard to add wheel base and have a starlet have the same footprint as an ae86. comes down to weight, and most im0ortantly personal preference
Mr Revhead wrote:
im going to say they are potentially the same. while having the pontential to be a bit different
frost wrote:how about comparing track times, any one have time slips around nz tracks of both car and mods list. thats the only way to prove anything, but then again the first post did point out that the starlet would be better for short tracks and ae86 full sooooo apples to oranges
Mmm, Boost wrote:Just buy a KE70 while they're still cheap, rear is identical to AE86, all the front stuff can swap over, and its not overly hard to upgrade the front of a KE anyway.
All you need then is a AE70 x member and you've got something that will go and turn like an AE86 for about 1/3 the cost
