ACL race bearings & ARP bolts
Postby TRD_ZERO » Sun Jun 24, 2007 12:26 pm
IM after some ACL race series bearing for my Blacktop, bigends and mains. Where abouts do i get them from and do i need to know someone in the trade to get them at that low price?? Can anyone help me out here?? And ARP bolts im planning on getting some rod bolts for my engine build but was also wondering about the mains cap bolts. Should i get the mains cap bolts?? I just dont want to spend money on unnecessary items. Im getting the arp rod bolts to prevent the bigends from going, well help prevent. Do i really need the mains caps bolts?? And can anyone help me out here on where to get them and maybe even trade prices?? :wink:
TRD_ZERO
Postby AceSniper » Sun Jun 24, 2007 12:41 pm
ACL bearings go order them from supercheap... there cheap as... repco you will pay more even if you get staff.
They have to order them in takes like a day,
cost All acl race from supercheap...
mains $66.64
Big ends $51.43
Thrust(std) $17.83
ACL 20v Premium rings $100.50
Get ARP rod bolts, doubt you will find them for less than $125 unless someone has a set they are trying to sell, mains wouldn't worry for the cost, I managed to score a set of new ARP main studs for $80 but I think there meant to be $260+?
AceSniper
Postby Fortyone.co.nz » Sun Jun 24, 2007 1:17 pm
M9 rod bolts - $90, M10 Flywheel bolt kit - $80. 16V head stud kit $225, 16V main stud kit $150
Fortyone.co.nz - For Bride, EBC, KTS, JUN, Tomei, HKS, Trust, Blitz and more!
Fortyone.co.nz
Postby TRD_ZERO » Sun Jun 24, 2007 2:22 pm
So flag the mains just use the standard ones and just get the rodbolts? those prices that you stated
mains $66.64
Big ends $51.43
at supercheap i just walk in and order them no staff discount required?
No need to worry about rings as i just got my new gze pistons in the mail and they came with new rings. I should maybe add that this is a blacktop turbo engine.
TRD_ZERO
Postby AceSniper » Sun Jun 24, 2007 2:49 pm
yep just walk in and order, they don't have listings so doit on a week day so they can ring up acl and order them, grab the part numbers you want off the acl website so you get the right stuff (they don't seam to have acl race books)
works out 100+ cheaper than repco I think from memory
http://www.aclperformance.com.au/Toyota ... arings.htm
Def use ARP rod bolts (as you should really replace them once used anyway)
Main bolts.... pending what you want to spend you can go with out them.
AceSniper
Postby TRD_ZERO » Sun Jun 24, 2007 7:28 pm
Thanks man that is just what i wanted...........one more question before i order them as i dont want to be getting the wrong things. There are two sets of part numbers and under them they both have STD with one having numbers following. Whats with the numbers? Are they for oversize? I just want standard size so what part numbers do i use?? I know its probably a stupid question and i must be overlooking something. Help?
TRD_ZERO
Postby Mr Revhead » Sun Jun 24, 2007 7:36 pm
STD.... an over used term....
measure your rods, measure your crank... then work out what size you need.
Postby AceSniper » Sun Jun 24, 2007 7:42 pm
there is stock an oversize, then the next number nearby is for xtra oil clearance, you probably don't want todo that, so you will be after the main part number then the size needed.... does pay to measure up to be sure
AceSniper
Postby Grrrrrrr! » Sun Jun 24, 2007 9:01 pm
TRD_ZERO wrote:No need to worry about rings as i just got my new gze pistons in the mail and they came with new rings. I should maybe add that this is a blacktop turbo engine.
What conrods are you going to use?
Blacktop conrods are well known for adding extra breathing holes to the side of your block at high revs.
Not sure how they like boost but silvertop or GZE rods would be much
better in my opinion.
Grrrrrrr!
Postby TRD_ZERO » Sun Jun 24, 2007 9:05 pm
Oh ok i got it now i didnt know id need to give a part number and the size i needed i thought there were different part numbers for the different sizes.
Ill measure up and see what i need lets just hope my measuring tape is accurate. :lol:
TRD_ZERO
Postby AceSniper » Sun Jun 24, 2007 9:27 pm
:lol:
hes said else were about using ae92/redtop rods
AceSniper
Postby TRD_ZERO » Sun Jun 24, 2007 9:33 pm
I didnt see that post must have gone up when i was typing out my last one.
Yeah im using the ae92 gze rods the fatter ones just as extra security.
TRD_ZERO
