2JZ-GE cams
2JZ-GE cams
Postby iainous » Mon Jun 25, 2007 4:08 pm
Im looking at getting some cams for a 2JZ-GE, aftermarket stuff is pretty thin on the ground for the N/A motor so im not having much luck finding some, any help would be appreciated.
iainous
Postby Volodkovich » Mon Jun 25, 2007 4:14 pm
Go to a reputable camgrinder and get them to regrind them for you to a different spec?
I would say kelford, CSL cams etc could do this for you
Volodkovich
Postby iainous » Mon Jun 25, 2007 5:57 pm
Have had a price of $950 from franklin cams, waiting for kelford to get back to me, you got a web site for CSL?
iainous
Postby Volodkovich » Mon Jun 25, 2007 6:07 pm
Look them up in phone book, dont think they have a website. They are in Palmerston North. Kelford would be my choice though, they probably have the best rep in NZ as far as cam grinding goes.
I've heard you can get some good gains out of the 2jz-ge, so let me know how you go. I am keen on using one for a project car later on. Heard they are a very underated motor.
I reckon 300hp at crank would be do able quite easily with mild cam grinds, upped compression, ITB's, exhaust and maybe a bit of light porting. But yea, let me know how you go
Volodkovich
Postby iainous » Mon Jun 25, 2007 6:23 pm
Sweet, yeah heard kelford were the best for regrinds, as far as mods go I have done itb's, extractors, link G3, want to do cams before I get it tuned, ive seen standard supras putting out 130rwkw so with the above mods it should go good
iainous
Postby Volodkovich » Mon Jun 25, 2007 6:29 pm
How'd you make your ITB manifold? Any pics?
pretty interested in these motors as i have said. Easy way would be going to 1uz-fe but i prefer the 2jz-ge.
Any idea about port/valve sizing on 1jz/1jzgte/2jz/2jzgte variants?
People have said they dont repsond well to n/a tuning but i believe that its because no one really gives it a good go before going turbo. I think 100hp/litre is pretty acheivable on a budget, though might take a bit of development. What do they put out standard? 220hp?
Volodkovich
Postby iainous » Mon Jun 25, 2007 7:58 pm
there are some photos here
http://www.garagedori.com/forum/viewtopic.php?t=2579
they are a bit old now as I have done heaps more to it.
The manifold is a standard lower half modified to accept 20v itb's cost me $400 to get done which I thought was very reasonable for the amount of work put in, as far as power in standard trim I believe they are 168kw and 300nm, getting power from the N/A is $$$ that is why most chuck a turbo on
iainous
Postby strx7 » Mon Jun 25, 2007 11:05 pm
225 hp and 285 N/m for a 1995/96 2JZGE
Postby Adamal » Mon Jun 25, 2007 11:30 pm
Hope you get some good gains. Its nice to see some originallity instead of the same old 'Get a turbo auuu!!' approach.
Postby strx7 » Mon Jun 25, 2007 11:32 pm
I plan on building a cammy 1JZ in a few years. I'm sure due to the short stroke It'd handle being abused to a lot of RPM ie:9K +
Postby gmacrae » Thu Jun 28, 2007 12:18 am
thats a cool project, ITB's will be rad on a 2j. Are you doing anything to the block? stock block should pull 8000rpm no probs, but more rpm would be pretty sweet. You planed the head at all?
gmacrae
Postby iainous » Thu Jun 28, 2007 2:39 pm
Not touching the bottom end or the head apart from dropping some cams in, plan to do some head porting and raise the compression on the spare motor I have at a later stage. Being a square bore/stroke I dont expect to rev it past 8000rpm, 3litre + itb's at 8000rpm = me very happy
iainous
