???s about k50s with 4ages in kp61s
Postby otazup » Mon May 21, 2007 7:42 pm
hey guys
im doing a kp starlet 4age conversion, and ive bought a k50 to mate up to the 4age. I know this is a pritty common box to use so any info on these qusetions would be much appreciated.
- Will the box bolt up in my starlet to the exsiting xmember, driveshaft, clutch cable and such?
-Would i run with a 4age clutch setup or a k series?
-And can i use a ke70 xmember and rubber on the box?
otazup
Re: ???s about k50s with 4ages in kp61s
Postby rwd_mayhem » Tue May 22, 2007 10:05 pm
otazup wrote:hey guys
not too sure on the x-member, id imagine itd just line straight up, if not it shouldnt be hard to make it fit, same for the clutch cable, driveshaft should fit straight in.
you have to use a 4age pressure plate and a 3au drive plate.
donno bout that, itd be easier using the gboxs x-member id say
current: 1975 Valiant Regel
rwd_mayhem
Postby aaron » Tue Jun 26, 2007 1:46 pm
HI I had a k50 on my 4age powered ke25 and have helped friends who have done the same conversion in starlets ans other corollas. the run down is, yes it will bolt straight in if it has the A series bell housing, you may need to modify the shifter hole depending on the tail shaft you use, If your starlet has a k50 just change the tail shafts over and its a straight bolt up ( incl drive shaft), you will need to get a modified clutch plate these are not that expensive and if you go to a clutch specialist they should no exactly what to do, I think my clutch plate and preasure plate cost me about 350. clutch cable should be sweet.
Owned cars:
4age powered 1973 ke25 corolla
4k powered 1974 ke25
AE101 20v trueno
AE92 Levin
http://toyspeed.blakjak.net/profiles/profile.php?id=68
aaron
Postby d1 mule » Tue Jun 26, 2007 1:49 pm
yeah my flatmate used a 4AGE clutch cover tith modified 4Age size plate with 3AU spline, easy as :D
d1 mule
Postby matt dunn » Tue Jun 26, 2007 7:30 pm
otazup wrote:im doing a kp starlet 4age conversion, and ive bought a k50 to mate up to the 4age.
How much did you pay for an A series K50?
I may be looking of one soon.
Matt
Postby frost » Tue Jun 26, 2007 9:07 pm
matt,
ive always sold A series k50 for about $150 or $200 if i know its real mint, so that the pricing, i've also seen one on TM go for stupid amounts of money, something like $400.
Postby thaphatty » Wed Jun 27, 2007 11:13 pm
Matt
i've got one
$100
thaphatty
Postby AE86less » Thu Jun 28, 2007 1:12 am
Sold mine for $40 :?
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
k50-kp60 conversion
Postby ezy10s » Thu Jun 28, 2007 9:24 am
3a k50 gearbox- best way (if you have the one of course) is to remove the 3a k50 tailshaft housing and replace it with the tail shaft housing from a starlet 5 speed gearbox,this means the shifter will come out the original tunnel hole and also means you retain the use of the orginal starlet crossmember and drive shaft.
As for clutch you will use the 4age pressure plate and a 3a k50 clutch plate
also use the 4age starter motor.
Member #244
Gone fishing until further notice
ezy10s
Postby aaron » Thu Jun 28, 2007 6:21 pm
For a A series k50 anything between 100-200 running is reasonable but yea have seen them go for more than that there in quite high demand at times
Owned cars:
AE101 20v trueno
AE92 Levin
aaron
Users browsing this forum: No registered users and 36 guests
