a series FWD gear box's?
Postby ke25sr » Fri Jul 06, 2007 7:43 pm
The MR2 has just had a axle come off at the flange. It has punched a hole in the Gearbox. ($&#$%)
How interchangeable are they. It has a Black top 4AGE in it and im sure its the original AW11 box (c52).
can any 1 tell me the differences?
ke25sr
Postby ChaosAD » Fri Jul 06, 2007 7:56 pm
Selectors are on a different side of gearbox compared to the FWD gearbox.
ChaosAD
Postby ke25sr » Fri Jul 06, 2007 8:01 pm
ChaosAD wrote:Selectors are on a different side of gearbox compared to the FWD gearbox.
dam.
can they be used?
ke25sr
Postby AceSniper » Fri Jul 06, 2007 8:02 pm
if you know how to split the box's and the middle section of the aw box casing is undamaged use it on the fwd box
way faster than modding the fwd selector to work.
Be best to use ae92/ae101 shafts if they fit, flanged shafts seam to letgo alot
AceSniper
Postby ke25sr » Fri Jul 06, 2007 8:06 pm
are the end housings interchangeable?
ke25sr
Postby AceSniper » Fri Jul 06, 2007 8:18 pm
yeap.
top housing 5th gear (all the same)
2nd housing has the selector mounts two versions rwd an fwd
Bell housing... there is the single and dual starter versions
some small things might change also but they can all be swaped
AceSniper
Postby ke25sr » Fri Jul 06, 2007 8:23 pm
awesome.
are the axles interchangeable wit anything.
ke25sr
Postby ChaosAD » Fri Jul 06, 2007 8:49 pm
the flange driveshaft bits sticking out of your gearbox can be removed with a bit of force and either fitted to another gearbox or other shafts used.
Im splitting a gearbox at the mo, 5th gear can be a bitch to get off but everything else is relatively straightforward with a manual.
ChaosAD
Postby ke25sr » Fri Jul 06, 2007 8:53 pm
My center housing has a hole and lots of cracks.
im now after a new box.
thanks for all the help.
awesome.
ke25sr
Postby Grrrrrrr! » Sat Jul 07, 2007 3:01 pm
So can a c56 be turned into an AW11 box by simply changing the center casing to an AW one? or is there too much of a difference between the internals?
Grrrrrrr!
Postby AceSniper » Sat Jul 07, 2007 8:25 pm
shouldnt be an issue, ... all of it is the same, just gears differ abit(stronger) along with ratios
AceSniper
Postby Grrrrrrr! » Sun Jul 08, 2007 12:33 am
Vely interlesting :D </bad accent>
Was wondering what to do with that c56 box i have :)
now i just need some $$$ and an AW
Grrrrrrr!
Postby crispy'86 » Wed Jul 25, 2007 7:21 pm
There's been a post already done with a link to convet one of those boxes to suit aw11 mr2.:
viewtopic.php?t=27645&highlight=fitting+mr2+box+ae82
crispy'86
