Mr Revhead wrote:cop cars are bone stock
have an optional suspension package
pjay wrote:Those V6's are just quick anyway. Was probly just a modded lower end subaru.. and why did he circle 3 times?? a bit stoopid?
IH8TEC wrote:Mr Revhead wrote:cop cars are bone stock
some get chipped.
Lith wrote:pjay wrote:Those V6's are just quick anyway. Was probly just a modded lower end subaru.. and why did he circle 3 times?? a bit stoopid?
I wouldn't go so far as to say they are quick, but they are quick enough to do the job - torque everywhere. The advantage would be in the short bursts of acceleration. Sucks to be the Subie guy, being gained on by a bunch of Buick V6 powered things
fuel wrote:Lith wrote:pjay wrote:Those V6's are just quick anyway. Was probly just a modded lower end subaru.. and why did he circle 3 times?? a bit stoopid?
VY onwards had the Alloytec quad cam engine didn't they? Totally different from the Buick pushrod lump.
lucasthefallen wrote:i work on alot of cop cars every week ( giltrap holden ) and they are all bone stock, no upgraded chips, suspension etc etc, the only difference between a cop car and normal commodore is the brake pads and the 5mm thick skid plate under the sump. the pursuit cars ae mostly sv6's the vz's rated at 190kws, and the ve's at 195kw's. at the engine, some are open diff it just depends. they even use the same tyres as fitted from factory.
method wrote:Some of the undercover cars are damn quick. Ive witnessed a black holden of some sort with shiny wheels and flashing blue and red lights gain on two evos that sped past it ad over 160kph, and it was stationary on the side of the motorway.
It was placed there after the first nightwars drags though.. so i guess it was waiting for some hotted up cars to go flying past.
And it was defiantly not limited to 180kph, and it defiantly pursued the cars at or over 180kph at times. The evos did not have a limiter either.
Funny thing is i was talking to one of the dudes back at the drags because back then i had a evo too. His car ran a 12.9 so it wasnt exactly slow.. and for a cop car to catch up to it....
They are a reasonably good handling car, with a reasonably good power plant with a reasonably trained driver
