Motec & boost control
Postby Wolf_Tm250 » Sat Jul 14, 2007 11:44 pm
Hello,
I need to control boost vs. rpm, and so I have to remove my Blitz SBC and control a solenoid valve with my Motec M4Pro output...
Question:
what kind/type of solenoid valve should I buy to control the boost ( external wg ) ?
Thanks in advance.
Wolf_Tm250
Wolf_Tm250
Postby fivebob » Sun Jul 15, 2007 12:42 am
I use the GM/Delco boost contol solenoid that Motec sells, though it's far cheaper if you can find a GM parts supplier that will sell you one (most will only sell to US customers).
Part #s are;
1997152 - Delco Boost Control Solenoid
12102747 - Connector for solenoid.
Postby matt dunn » Sun Jul 15, 2007 1:06 am
OR,
1990 RS legacy have a denso 3 port solenoid in them,
it's under a cover by the 4 channel igniter on the R/H? strut tower.
That's we use with our M600, and we used with our links etc too.
Postby Wolf_Tm250 » Sun Jul 15, 2007 8:02 pm
Thank you for the advice.
Unfortunately I'm not able to find GM or older Subaru parts here in Italy...
I'll buy the Motec valve then...
Bye !
Wolf_Tm250
Wolf_Tm250
Postby Wolf_Tm250 » Thu Jul 19, 2007 5:56 am
fivebob wrote:I use the GM/Delco boost contol solenoid that Motec sells, though it's far cheaper if you can find a GM parts supplier that will sell you one (most will only sell to US customers).
Part #s are;
Sorry fivebob,
but a US friend checked for me gmparts and the 12102747 seems to be a
radiator cap...
Wolf_Tm250
Wolf_Tm250
Postby fivebob » Thu Jul 19, 2007 2:11 pm
Part #s are;
Sorry fivebob,
radiator cap...
GMPartsdirect.com lists it in the Radiator Tank Cap category, but calls it a Connector. It is definitely the correct part # and someone is selling one on EBay for $US7.50. Perhaps you could ask them if the can get the solenoid as well.
Postby Wolf_Tm250 » Thu Jul 19, 2007 6:35 pm
fivebob wrote:
Part #s are;
Sorry fivebob,
radiator cap...
Thanks fivebob
Wolf_Tm250
Wolf_Tm250
Postby Wolf_Tm250 » Thu Aug 02, 2007 5:10 am
Hello,
finally I received the GM solenoid this morning !
Any advice on how to connect the 2 hoses for the external wastegate, and the wires to the M4 ecu ?
Thanks.
Wolf_Tm250
Wolf_Tm250
Postby fivebob » Thu Aug 02, 2007 6:07 am
Postby Wolf_Tm250 » Thu Aug 02, 2007 8:18 am
8O 8O 8O 8O
Thanks a lot !!!!
Wolf_Tm250
Wolf_Tm250
Re: Motec & boost control
Postby matt dunn » Thu Aug 02, 2007 8:12 pm
Wolf_Tm250 wrote:I need to control boost vs. rpm,
What is the reason for that?
Postby Wolf_Tm250 » Thu Aug 02, 2007 8:15 pm
Simple,
increase power/torque in some rpm ranges... :wink:
Wolf_Tm250
Wolf_Tm250
