sergei wrote:I was thinking about that, and theoretically scoops are in the low presure area and will not pressurise the engine bay. In fact the air will not really flow anywhere, you willl have a cylindrical "vortex" (I can't think of the right term).
sergei wrote:You are right, but only if scoop is reversed. With scoop other way arround (facing front) or no scoop will hardly make a difference.
snwtoy wrote:sergei wrote:You are right, but only if scoop is reversed. With scoop other way arround (facing front) or no scoop will hardly make a difference.
I've *heard* that on an ST205, changing the bonnet, or blocking the part of the scoop which vents onto the cambelt is a sure way to bring about the death of said cambelt.
So there is definitely *some* effect worth having. Toyota engineers wouldn't have put it there otherwise.
sergei wrote:snwtoy wrote:Only on rally cars running antilag and heaps of boost.
On my ST205 that little vent goes into the cambelt cover but I doubt it is actually the same thing they used in rally (probably there for exterior homologation rules). With big hole in the bonnet in ST205 - it does nothing again - it is covered by heat shield and plastic cover with small holes to drain water when it is raining (I plan to remove it when I find a good stick on insulation material).
Oh and my ST165 runs a lot hotter, and I have no problem with cambelt disintegrating (although the cover is slightly heat damaged under alternator). Also big hole in the bonnet helps.
sergei wrote:I did not know that caldina had cambelt vent.
postfach wrote:sergei wrote:I was thinking about that, and theoretically scoops are in the low presure area and will not pressurise the engine bay. In fact the air will not really flow anywhere, you willl have a cylindrical "vortex" (I can't think of the right term).
I once read an article somewhere where they tested a few different bonnet vent designs/placements and the ones that had the opening facing the rear actually lowered engine bay temps more than the ones facing forwards due to the differing pressures in different places on the car, the air rushing over the top created a low pressure zone and "sucked" air out of the engine bay.
I'd look for the article but I'd rather play with my new xenon lights
