linkplus boost control
Postby MR2SIK » Wed Jul 18, 2007 6:00 pm
Recently got my car tuned, is going great :D
But on the way home I noticed the boost spiked in 3rd and 4th gears. The closer I got to Nelson the more frequently it did it. Thought it may have been the freezing air temps.
My i/c pipes were leaking a bit before the tune and they got looked at and fixed. Would leaking pipes cause it to shoot over?
My other thought is the gain type setting on it may be set a bit high? but it hasnt been touched since the dyno.
Thought id ask here before making a toll call to the workshop.
And does anyone have any preference to particular brands of silicone pipe joiner and clamps? I think my ones are on the cheap and nasty side.
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby matt dunn » Wed Jul 18, 2007 9:46 pm
what version of ecu?
g3? g1?
The g3's are all open loop boost control at this stage so if you fixed boost leaks, you will get more boost.
Postby MR2SIK » Wed Jul 18, 2007 10:09 pm
g1, lpv(?)14 if it makes any difference
MR2SIK
Postby Tukumi » Thu Jul 19, 2007 12:22 am
Hey, two main things that will cause the boost to spike on your setup.
1 is the wastegate hold value. To setup the boost control for the road set the wastegate hold value to 1 then test the boost control in the gear that it is giving you trouble in, if it still spikes then its more than likely the wastegate base number, from memory yours was set on 50, this may need to be more like 45. You basically need to adjust the base number up or down until the boost comes on to within a psi or so then the closed loop boost control will take over from there. Once you have that right you can bring the wastegate hold number back up untill it starts to spike then back it off slightly.
If you have any trouble let me know and i could give you a call.
Hows it going apart from that?
Cheers Phil
NZEFI
AE85 4AGTE, 11.9@115mph <--Watch this space 229kw at the wheels ***sold***
WWW.NZEFI.COM
WWW.DORIMONS.COM
Tukumi
Postby mjrstar » Thu Jul 19, 2007 11:10 am
i have a link plus in my car and i went away from using the link to control boost it just seems so slow to react. personally id go for a gizmo EBC as they are easy to set up and relible. i have a greddy profec EBC which does work well but is not all that simple to set up.
other people may have had better luck with the link running the boost control but found it produced fairly lack-lusture result on my car.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby Al » Thu Jul 19, 2007 1:56 pm
mjrstar wrote:personally id go for a gizmo EBC as they are easy to set up and relible.
:lol:
He uses one as a boost gauge :lol:
Al
Postby Crucible » Thu Jul 19, 2007 2:16 pm
mjrstar wrote: personally id go for a gizmo EBC as they are easy to set up and relible.
once you know how that is!!, the instructions suck balls, but MR2SIK already knows all about setting them up lol
hes the one who helped me sort my Gizzmo EBC out. :P
Crucible
Real Life Mechanic
Postby MR2SIK » Thu Jul 19, 2007 5:45 pm
Tukumi wrote:Hey, two main things that will cause the boost to spike on your setup.
Cheers Phil
NZEFI
Cheers Phil, will go have a tinker and report back, Its going great :D completly exceeded my expectations. It just hits so much harder than before, found myself in a few licence losing situations on the way home :lol:
And yea, I have a Gizzmo ebc, but It broke. Launching on a track just after 2 jet cars have gone down it provides a fair bit more grip, resulting in said controller flying out of the dash and ripping the connections in the process :x
MR2SIK
Postby MR2SIK » Thu Jul 19, 2007 6:25 pm
Great Success 8)
Hits 17.x psi before levelling on 16 flat
Thanks for the help :)
MR2SIK
Postby MR2SIK » Fri Jul 20, 2007 7:18 pm
and now for todays retarded question :lol:
Dropped the wastegate base number to 45 and all was fine, went home and shut off the car, went out a while later and bang, 19psi again... Checked the controller and it set itself back to 50. How do I save changes using the hand controller? I go to the store screen then what?
Im such a n00b :lol: :lol: :oops:
MR2SIK
Postby matt dunn » Sat Jul 21, 2007 12:42 am
I think that when it says store on the screen you hold both the adjust buttons at the same time until it reads *********** on the screen.
Been a while since i did and adjustment with a hand controller, but I'm sure it those two.
Postby MR2SIK » Sun Jul 22, 2007 2:18 am
:D Cheers Matt,
I remembered reading somewhere you had to press 2 buttons together to save changes, but couldnt remember which 2..
MR2SIK
Users browsing this forum: No registered users and 35 guests
