I have the idle sorted, it will idle fine now. But the problem is, the car will stall after about 10 seconds everytime. Appears to be no codes now (showed some intake codes, fixed and went away). What could cause it to stall after a certain time?
And i put my radiator in this morning, i have a big water leak down the back of the motor somewhere. It drops onto the north-south crossmember. What water pipes do i have behind here?
