Aftermarket Steering Wheel Horn Button Question
Postby haydo » Fri Jul 20, 2007 10:23 pm
I bought a new steering wheel as below:
I've installed one before but this one is slightly different. It has two horn buttons as pictured and I don't know how to connect it up as both sides have a very short (1 cm at most) red and blakc wire coming out of the back of it with none of those spade things on it just plain wire. Anyone have any ideas on how to connect the horn up
haydo
Postby slighty_sykotic » Fri Jul 20, 2007 11:22 pm
um... Join a spade terminal to the end of the wire?...
slighty_sykotic
Postby haydo » Sat Jul 21, 2007 6:34 am
oh yeah true. Don't boss kits usually come with a spare?
haydo
Postby haydo » Sat Jul 21, 2007 5:17 pm
Here's a picture of what i mean by the wires etc.
Would someone mind explaining to me what exactly I do to get the horn working cheers. This one is much different compared to one I had lst time round.
haydo
Postby IH8TEC » Sat Jul 21, 2007 5:24 pm
is it second hand? solder some wire to it and heat shrink.
Postby haydo » Sat Jul 21, 2007 5:26 pm
it's brand new. sorry do you mind elaborating lol
haydo
Postby postfach » Sat Jul 21, 2007 6:30 pm
ok, looks like that ring thing in the first pic is gonna be your earth, so:
1) solder one wire to the black wire on the button, and put a spade terminal on the other end and put that onto the tab thing on that ring, then
2) take the wire from the boss kit and solder it to the red wire on your button
once you screw the wheel to the boss kit, the horn will work
guess i should mention you should cover the wires where you have soldered with heatshrink or electrical tape.
postfach
Postby postfach » Sat Jul 21, 2007 6:33 pm
suppose you could use the second button for some sweet NOS action or to turn your neons on too...
postfach
Postby haydo » Tue Jul 24, 2007 10:16 am
Ended up just connecting both buttons to the horn and it worked. cheers for your help.
one more question how do you get the indicators to flick off automatically when i have completed the turn? i cant work out how
haydo
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
