4age problem
4age problem
Postby kpimpin61 » Sat Jul 21, 2007 1:46 pm
hey guys i have a 4age redtop 16v in my kp61 starlet was running mint bout a year ago then i decided to change suspension etc etc etc havent dicked round with the wiring the whole time now it doesnt go?
i have all the power feeds to the computer that i need but no spark no check engine light and the fuel pump only goes when the cars cranking(usually the fuel pump would stay on for a couple seconds after cranking if the motor did not start)
what you rekon guys?
kpimpin61
Postby ChaosAD » Sat Jul 21, 2007 4:42 pm
getting power to the coil and injectors?
ChaosAD
Postby kpimpin61 » Sun Jul 22, 2007 11:36 am
yup theres power at the injectors and power to the coil but no spark?
kpimpin61
Postby gepsk8 » Sun Jul 22, 2007 7:20 pm
check coil.
gepsk8
Postby kpimpin61 » Sun Jul 22, 2007 7:28 pm
tried another coil and ignitor but nothing
starting to get confusing now
kpimpin61
Postby Kender » Sun Jul 22, 2007 11:06 pm
My guess is you've unplugged something during your etc etc work, and forgotten to plug it back in/plug it back in properly.
'84 AW11 SC racecar "RDDWRF"
'92 SW20 GT-S
'91 GT Legacy wagon
Kender
Postby gepsk8 » Mon Jul 23, 2007 6:36 pm
hey, where in welly u located? u mind if i come have look?
gepsk8
Lights on but no-one home...
Postby jondee86 » Mon Jul 23, 2007 8:45 pm
Camshafts turn when you crank ??
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby kpimpin61 » Tue Jul 24, 2007 7:45 pm
the whole loom is plugged in its wired so theres a plug at the computer then a plug at the sensor thats all no plugs inbetween evrythings plugged in that needs to be
im in upper hutt what would you be looking at?
yeap camshafts turn it isnt running a top cam cover so easy to see, cam timing is spot on
kpimpin61
Postby gepsk8 » Tue Jul 24, 2007 8:31 pm
everything in way, hard to explain, pm if u want me to have look?
gepsk8
