slighty_sykotic wrote: If a thermostat is working corectly, how the hell can any amount of cooling lower the temp below the thermostat point. And whatever you said about the trd/tom thermostats has nothing to do with this convo at all...
TWSTD wrote:exactly - so the only time it will ever make ANY difference is when the radiator cannot perform its job sufficiently. Lets just all accept that they are a costmetic item - not that theres anything wring with that - they certainly do a good job of sprucing up ones engine bay. Ive considered buying one of the flash US made carbon items we sell even....
TRD Man wrote:The relevance of the TRD thermostat is, in fact their purpose. A TRD thermostat, which opens 10 degrees earlier than a standard item, is not there to remedy problems with overheating. It's purpose is to lower the operating temperature to achieve more power.
There is an optimum temperature for an engine to maintain to achieve best power. Others may be more expert in this but my understanding is that this is about 70 degrees.
RomanV wrote:If this is true, then why do 'normal' thermostats keep the engine at a higher temperature? Surely there must be a downside too, otherwise all thermostats would open earlier?
RomanV wrote:TRD Man wrote:The relevance of the TRD thermostat is, in fact their purpose. A TRD thermostat, which opens 10 degrees earlier than a standard item, is not there to remedy problems with overheating. It's purpose is to lower the operating temperature to achieve more power.
RomanV wrote: If this is true, then why do 'normal' thermostats keep the engine at a higher temperature? Surely there must be a downside too, otherwise all thermostats would open earlier?
barryogen wrote:A few weeks ago I got one of these for my 01 RunX(Corolla) from Mac at http://41.co.nz.
I'll freely admit that I got it mostly for looks and didn't think that it would make a hell of a lot of difference.
However, when driving along around town it keeps the car a bar and a half lower on the temp gauge, and when fanging the car it keeps it at normal, a full three bars below where it used to sit when given a thrashing.
I intend on getting actual readings of what the temps are, but for the moment I'm certainly pleased with my relatively cheap purchase, and the better cooling that it has given.
Thank you Mac from 41 and Toyspeed for the discount.
lee90 wrote:
where can you get C-One cooling panel for ae111?
lee90 wrote:ohh i found it $170 nice price dus it really work though?
gmacrae wrote:sounds like your cooling system was messed up to begin with - no (healthy) toyota i've ever driven has moved the guage from normal operating temp when giving it some stick - something aint right there
postfach wrote:I could be way off track here, but I don't think that the point on the gauge that indicates "normal" operating temperature is the same point at which the thermostat opens....
A thermostat is a mechanical thing, it operates in a set temperature range, if the water passing the thermostat is cooler after installing the panel, then the thermostat will just open less... (it's not broken!)
Yes, the water will warm up more if the thermostat is closed, so yes, it will open up more again and the water will cool down again. The normal operating temperature is an EQUILIBRIUM. One side of the equation has been changed (the panel installed) THE EQUILIBRIUM MOVES!
The temperature gauge indicates the temperature of the water in the cooling system (OH MY GOD!!) not the operation of the thermostat.
In short, the panel is working, the thermostat is working. No problem.
Users browsing this forum: Bing [Bot] and 28 guests
