fuel lines
Re: surge tank
Postby Rick » Thu Aug 02, 2007 7:35 pm
Steelo wrote:
panda_dan wrote:Steelo: Yep that's the guy made my surge tank I think.
Just get one with one 12mm outlet on the bottom for your feed, and 3 10mm outlets on the top. Those trademe guys should make to your requirements no extra cost if you ask nicely.
doin_donuts: I'll be in touch over the weekend if I get some time to work on the car on sunday prob most likely.
Danny
When you say 3 10mm outlets on the top, one is the feed to the surge tank and one is the fuel return to the tank......whats the third one for? breather?
Also, are you able to take some photos of your setup? :D
There are a few ways of doing it but I like the idea of the return from the motor going into the main tank rather than the surge tank. Remember got to have an overflow on the surge tank
Postby matt dunn » Fri Aug 03, 2007 12:38 am
We always run our race cars and the one's we build so that the fuel return from the engine is to the surge tank.
That way the lift pumps only have to flow as much to the surge tank as the engine uses, ( which in some of our car is quite a lot).
If you return it to the main tank you risk getting surge in the surge tank,
as the main pump is usually outflows the pumps that feed the surge tank,
and then you can run the main tank to 100% empty if you have to.
My car is setup knida like that and wont get surge in the tank untill there is less than 500ml petrol left in the entire car. ( almost enough for one lap of teretonga on super cruise mode).
Matt
surge
Postby panda_dan » Fri Aug 03, 2007 9:38 am
oh yep sorry i got another pipe put in at the top of minde in case i ever wanted to run another pump
so it's blanked off at the moment
yes i'll get some photos this weekend for ya
panda_dan
Postby Meadzy » Sat Aug 04, 2007 12:29 pm
on my 20v coversion just used a new 10mm fuel hose for the supply, used the original supply for the return.
with a external fuel pump and ae85 tank
havnt had any surging problems ever cornering hard even when fuels low, havnt tested on track yet tho
"Keeping it true to the JDM"
J-Spec Group
http://jspecgroup.com/forums/index.php
AE86,200sx,EG6
Meadzy
