AE111 Superstrut Knocking
Postby Timoz » Sat Aug 04, 2007 10:34 pm
Does anyone know how much around to replace the superstrut lower arms for a AE111 BZ-R? My left front started to knock few weeks ago and i also notice a knock coming from the driver sidetoo i will only do it when i put my step my foot on gas a bit more than usual, is this knock from the lower arm as well of is it something else? cheers guys
Timoz
Postby Bling » Sun Aug 05, 2007 1:23 am
for toyota parts follow this
viewtopic.php?t=44317
without looking at it no one will know exactly why your cars knocking, so unless you have the know-how to find ouit yourself... best to get it checked out by a professional
Postby Timoz » Sun Aug 05, 2007 12:28 pm
i got it checked at a suspension place, they say its the lower arm
Timoz
Postby CXGPWR » Tue Aug 07, 2007 6:28 pm
I had this problem in my AE111 BZ-G Levin, with super strut. I found it to be the suspension knuckle, its a little link between the lower arm & something else, only a couple of inches long with a hole in one end & a tapered ball-joint like end. These allways have a tendency to wear out. You can get a re-conditioned one from somewhere like john bates suspension, or go genuine for about 4x The price. Hope this helps.
CXGPWR
Postby spark_38 » Fri Aug 10, 2007 10:49 pm
I think it's the bit i've circled in red with two inner ball joints (according to a mechanic)
I have the same problem in my AE111 BZ-R levin, it started off as a squeeking sound - now the ball joint is worn out
Toyota have quoted me $244+GST for the part
spark_38
Postby Timoz » Sat Aug 11, 2007 3:37 am
you know how much it cost for the part?
Timoz
Postby Ae92typeX » Sat Aug 11, 2007 10:19 am
You didnt get a quote from the suspension place that checked it?
Email Revhead (for parts), or call your local toyota to quote.
Ae92typeX
Postby CXGPWR » Sat Aug 11, 2007 2:30 pm
Yeah thats what i was talking about, from john bates in palmerston north cost me $115 exchange. (that was at start of the year.) Thoes parts wear out quite quickly when the vehicle has been lowered.
CXGPWR
Postby Mr Revhead » Sat Aug 11, 2007 4:06 pm
those parts wear out quickly when rebuilt
TS price on that little part above is about $115
Postby Timoz » Sat Aug 11, 2007 4:17 pm
ok cool thanks guys
Timoz
Postby Timoz » Sat Aug 11, 2007 4:23 pm
Hey Mr RevHead, can u give me a exact quote for a pair of these little parts for my front left and right? please send the quote to timothytong1986@hotmail.com cheers.
Timoz
Postby Steelo » Sat Aug 11, 2007 5:47 pm
Heh, I replaced the RH ball joint this morning in my Trueno!
2012 Subaru WRX
1985 Toyota Levin
2014 Yamaha MT-07
Steelo
Postby Timoz » Sat Aug 11, 2007 9:37 pm
how much did the labour cost?
Timoz
Postby Steelo » Sat Aug 11, 2007 11:54 pm
Timoz wrote:how much did the labour cost?
If your talking to me, umm nothing; its pretty easy to do. Do it yourself.
2012 Subaru WRX
1985 Toyota Levin
2014 Yamaha MT-07
Steelo
Postby Timoz » Sun Aug 12, 2007 1:59 am
how do u take it out and put it back in?
Timoz
Postby Lloyd » Sun Aug 12, 2007 9:36 am
Just check its not on the arm that that little one bolts to. Have seen a few wear out that centre joint. And getting those 2 arms apart can be a bitch of a job and you don't want to be doing it twice, especially if you end up damaging the thread on the longer arm which is quite likely
Postby spark_38 » Fri Aug 17, 2007 9:18 pm
Changed the little piece over tonight relatively easy (using only a jack, some spanners and a few other tools)
Found out also it is the lower arm that the small piece (above in red) fits onto that's causing the sqeeking sound. so i suspect the ball joints in that are also on their way... anyone have a fair idea on the price of that part?
spark_38
Postby Bling » Fri Aug 17, 2007 9:57 pm
Timoz wrote:Hey Mr RevHead, can u give me a exact quote for a pair of these little parts for my front left and right? please send the quote to timothytong1986@hotmail.com cheers.
YOU email him, check in sponsors section of forum for contact details
Postby Timoz » Fri Aug 17, 2007 10:22 pm
if it is the control arm u are looking at about 150 to 190 depends who u get it from, i think Mr.Revhead will sort you out just ring him up as see.
Timoz
Postby spark_38 » Sun Aug 19, 2007 4:28 pm
just to confirm the control arm is the bit i've circled in blue.
the red piece is already been replaced
spark_38
