4agze goes chuff??
4agze goes chuff??
Postby pjay » Sun Aug 12, 2007 2:13 pm
Ok so i relocated my battery to the boot and installed a cold air box yesterday (very carefully)..The car was sweet! could definately notice an increase in power after the box was in..
Woke up this morning, but when i started the car i knew something was wrong. it didnt hold idle at first, just died..After the engine warmed up a bit i went down the road a bit and noticed i have no supercharger light, and no power, so no supercharger at all really!
Limped the car home and checked all the intake and there is no blocks or leaks or anything like that.
Basically the car idles fine. but when the throttle is opened it goes bleugh.. and when the throttle is opened quickly, the intake goes "chuff" and revs drop down to 100 before reaching idle again! The supercharger is not working.. im stumped
Could the s/c be stuffed? Did my cold air box intake stuff something?
If anyone has a spare 15 mins and wouldnt mind stopping by to tell me whats buggered, that would be champion!
Thanks
pjay
Postby rollaholic » Sun Aug 12, 2007 2:42 pm
more likely to be related to some wiring you've disturbed with the battery relocation than the intake change.
edit - 101 GZE's arent AFM are they?
Postby themaleman » Sun Aug 12, 2007 3:36 pm
yea there MAP sensored, checked u didnt disturb any of the plugs round the s/c? engine check light coming on? checked s/c fuse? (if thers such a thing)
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby pjay » Sun Aug 12, 2007 5:04 pm
engine light is on.. all fuses are intact. maybe its the s/c clutch? i hope the friggen thing hasnt seized :cry:
Anyone know how to remove the s/c?
pjay
Postby sergei » Sun Aug 12, 2007 5:21 pm
check if the MAP sensor is still connected (vacuum tube).
Postby pjay » Sun Aug 12, 2007 5:22 pm
sergei wrote:check if the MAP sensor is still connected (vacuum tube).
yup. sure is.. there is no boost. engine only revs to 5000rpm, no higher.
Smell of petrol is STRONG.. im guessing not enough air because the s/c isnt blowing :?: :idea:
pjay
Postby Si » Sun Aug 12, 2007 5:54 pm
What sort of earthing does your moved battery have?
Current: , '96 SubaruImpreza
Si
Postby pjay » Sun Aug 12, 2007 6:42 pm
battery is sweet. 0G positive -->> 200A c/b -->> distro -->> 2x4G to engine. 0G grounds at battery.
pjay
Postby Mr Revhead » Sun Aug 12, 2007 7:10 pm
pjay wrote:engine light is on.. all fuses are intact. maybe its the s/c clutch? i hope the friggen thing hasnt seized :cry:
checked the code?
Postby pjay » Sun Aug 12, 2007 7:20 pm
Im not totally sure how to check error codes.. i know theres a lamp used? and it blinks.....
pjay
Postby Boosted_162 » Sun Aug 12, 2007 7:30 pm
Bridge E1 and TE1 in the diagnostics box, and count the flashes.
Code meanings here viewtopic.php?t=35814.
You may have to reset to clear old codes. Pull efi fuse to do this.
Postby Mr Revhead » Sun Aug 12, 2007 7:31 pm
use a piece of wire or paper clip etc to bridge terminals T and E1 in the diagnostics port in the engine pay. from memory around the l/h strut area.
turn key on, count the flashes.
an ok code is a constant flash
like
a code will have a gap between it and the next code, a double digit code will have a small gap between the series of flashs and a larger one for the next code
----- -- = 52
----- -- --- -- = 52 and 32
Postby pjay » Sun Aug 12, 2007 8:28 pm
Fcukng sweet! thanks guys.. ill do that now and post up my results. do i need to connect a lamp? or is there a light in there?
pjay
Postby no_8wire » Sun Aug 12, 2007 8:44 pm
I think its the check engine light that you count the flashes off?
no_8wire
Postby pjay » Sun Aug 12, 2007 8:49 pm
no_8wire wrote:I think its the check engine light that you count the flashes off?
i hope not. means i gotta connect those terminals then run round to the drivers seat. what if i miss something?
pjay
Postby Mr Revhead » Sun Aug 12, 2007 8:53 pm
it repeats untill u disconnect it.
and wont start untill u turn the key to "on"
Postby pjay » Sun Aug 12, 2007 9:19 pm
ahh.. maybe im not doing something right.. the engine light is just staying on.. no flashes.
TE1 and E1 are bridged.. i turned the key to 'on' then 'acc' and even started the engine.. but no flashes
pjay
Postby Dell'Orto » Sun Aug 12, 2007 9:52 pm
You might have to clear the gunk out of the diagnostic box, it wont work unless you have a good connection.
Postby pjay » Sun Aug 12, 2007 10:01 pm
bugger.. degreaser? or is that too harsh?
pjay
Postby method » Sun Aug 12, 2007 11:10 pm
I always bridge it at the ECU.
You just need to earth T.
(E1 stands for earth)
PICS UPDATED DAILY
method
