same number of valves. same family of engine.BZG|Bling wrote:Different cylinder Head
blacktop head over silvertop head, so to be legal it needs a cert for that too.
All depends how legal you want to be, but at end of the day.
Leon wrote:If you don't cert, and then crash the car. The insurance assesor might spot the conversion, at which case your heading towards the insurance company refusing your claim
Leon wrote:sergei wrote:Basically certs are all about safety
I didn't mention safety ... I mentioned insurance companies looking for a way to not pay you.
Section 4.2 wrote:Engine Modifications that do not require certification.
A vehicle is not required to be certified to the Low Volume Vehicle Code provided that the safe performance tof the vehicle is not compromised, where the only modifications to the vehicle are those to the engine originally fitted to the vehicle by the vehicle manufacturer, that result in an increase of no more than 20% in an engine power output from the original vehicle manufacturers specifications
Section 4.3 wrote:Engine conversions that do not require certification
A vehicle is not required to be certified to the Low Volume Vehicle Code provided that the safe performance of the of the vehicle is not compromised, where the only modification to the vehicle is the fitting of an engine other than that fitted by the vehicle manufacturer and that the engine:
- Is of the same or less capacity or power output; and
- Is of the same configuration; and
- the fuel type is not changed from petrol to diesel or vice-versa; and
- has the same type of fuel induction system;
- has the same weight, location and centre of gravity; and
- Is of the same design and casting family of cylinder block and cylinder head(s)
Lith wrote:Black tops make almost as much as silvertops are claimed to make from factory - you'll be fine![]()
Also, the "25% more than factory" thing - I think I'm the only person I know of to be pulled up on by the frikken rule at a WOF station
Distrb wrote:20% Power output only applies to modification of existing engines, not conversions.
as stated in The Low Volume Vehicle Standard Engine and Drivetrain Conversion document; Effective 1 Sept 2002
http://www.lvvta.org.nz/Engine&Drive-tr ... ions09.pdfSection 4.2 wrote:Engine Modifications that do not require certification.
but the one that holds the answer is in fact this section:Section 4.3 wrote:Engine conversions that do not require certification
Following that, because the blacktop is rated at higher power output, you require certification for your car to be legal to the letter of the written law.
So how much you wanna try weasel your way around the semantics of it all is up to you.
Section 4.3 wrote: the fitting of an engine other than that fitted by the vehicle manufacturer and
d1 mule wrote:Lith wrote:Black tops make almost as much as silvertops are claimed to make from factory - you'll be fine![]()
you got sulled up for 183 at the wheels thats pretty much standard,what a joke lol the wof guy musnt oh had a root for a while what a c**t
