Telling the difference between a 3sfe and a 4sfe
Postby Charged1 » Mon Aug 27, 2007 4:13 pm
Hello does anyone know how to tell the difference between a 3sfe and a 4sfe engine , its in a 95 Carina , the plate says 4sfe but the guy selling it says its had a 3sfe put in it ? also is there a site that you can load in your cars frame/model number to find out the exact model it is meant to be , Thanks
Charged1
Postby sergei » Mon Aug 27, 2007 4:22 pm
Carina will most likely have 4SFE. On the engine block it should say either 3S of 4S followed by 6-5 numbers.
Postby Dirtbag » Mon Aug 27, 2007 7:39 pm
could also check the model, if it has 1.8 or something in it, just one other thing to back up the engine plate saying 4sfe, afaik they never came with 3sfes, only 4sfes and 7afes, it was the corona that came with a 2L engine (possibly a 3sfe?)
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Re: Telling the difference between a 3sfe and a 4sfe
Postby Jason T » Mon Aug 27, 2007 7:50 pm
Charged1 wrote:Hello does anyone know how to tell the difference between a 3sfe and a 4sfe engine , its in a 95 Carina , the plate says 4sfe but the guy selling it says its had a 3sfe put in it ? also is there a site that you can load in your cars frame/model number to find out the exact model it is meant to be , Thanks
Square HT lead 4SF/3SF Has engine code stamped at the gearbox end of engine between head and gearbox top edge (bellow and left of dizzy)
Early round lead 4SF has engine code stamped behind exhaust maifold in line between oil filter and starter
Fixing Toyota's since '87
Jason T
Postby Charged1 » Mon Aug 27, 2007 8:25 pm
Thanks Guys for your help
Charged1
