7agze ????
7agze ????
Postby toy boy » Tue Aug 01, 2006 2:05 am
i am thinking about building a new motor for my gtz and wanted to know what is the go with a 7age
i like the ze power and want to keep it but was thinking what sort of power people are making from these engines and can it be super charged?
and what parts dose one use to build one of these motors?
will be thankfull for some input
due to the lak of intrest the light at the end of the tunnel has been turned off
1989 ae92 treuno gt apex (mate rolled)
1991 ae92 treuno gtz (mate hit)
1988 ae92 treuno gtz (therd time luky)90% done
i have some ae92 parts avalabe so send me a pm and will get back to you
toy boy
Postby no_8wire » Tue Aug 01, 2006 8:27 am
For parts needed...
Search...
http://forums.toyspeed.org.nz/viewtopic.php?t=42696
I cant see why the sc wouldnt fit, may need to elongate the brackets to deal with the extra deck hieght.
no_8wire
Postby Jebus » Tue Aug 01, 2006 9:13 am
And you would probaly want to run an SC14, as opposed to SC12. To match the bigger displacment.
Jebus
Postby Mr Revhead » Tue Aug 01, 2006 10:08 am
we need to FAQ some info on these
sc14 for sure
Postby Jebus » Tue Aug 01, 2006 10:15 am
We really need as many members to write a short article on doing a particualr common thing that they are good at, wether it be swapping a diff head, or swapping blue top cams, showing the results, how to do it etc to compile into the FAQ.
Would be quite useful.
Jebus
Postby FXGTV » Tue Aug 01, 2006 12:13 pm
Jebus wrote:We really need as many members to write a short article on doing a particualr common thing that they are good at, wether it be swapping a diff head, or swapping blue top cams, showing the results, how to do it etc to compile into the FAQ.
Someone get that man a DB :P
1988 r31 TI Skyline.
1982 ra60 Celica (my Aussie Toyota and axle stand warrior).
ex: 1991 Corolla, 1989 fxgt-v, 1985 aw11. 1992 sw20 gt-s. 2002 glxi Lancer wagon (work hack)
next car - another a-dub please!
FXGTV
hey
Postby ezy10s » Sat Aug 05, 2006 12:42 am
i actually set one up in a kp i had a while back
7afe with16v bgpport head with complete sc12 manifolding and s/c.
omly issue i encounterred ws the extra 10mm-ish in height of the 7afe block, this meant the top locating bolts for the SC didnt line up with the holes into the inlet manifold- easy fix i just used some fat washers to clamp it together and all good.
same with the throttle body pipe that runs into the SC hole were out i just made a bracket to stop it flopping about and sorted.
I ran a 14psi pulley so needed to file the top of the alloy sump cradle as the pulley fouled it by about 4mm- its just the raised rib that hit.
Oh and the top water pipe that ran to the back of the head- hmm what did i do there... i think i cut it off and ran a rubber hose to clear the SC bits- or was that only because i was running the wrong water pipe? hmm cant quite remember sorry.
I had it all set up ready to runwith water air cooler and everything but as i do i got bored so sold it all off as parts so never had it running sorry.
Dont forget- if you change to 4age pistons Doesnt matter which ones the compression will go up
Member #244
Gone fishing until further notice
ezy10s
Postby toy boy » Sun Aug 06, 2006 11:43 pm
thanx peolpe this has helped a heap
i am planing on doing it for next year bit low on the $ required
toy boy
Postby solitaire » Sat Sep 08, 2007 11:14 am
toy boy wrote:thanx peolpe this has helped a heap
Did you get anywhere with this mate?
AE92, KZJ120, KDJ120
solitaire
Postby rollaholic » Sat Sep 08, 2007 12:27 pm
actually my understanding is that using 4a pistons will lower the compression considerably, because the 7a stock pistons are taller.
if you are going to run any kind of boost you'll want gze pistons, and accordingly the block needs to be decked to maintain decent compression.
theres a couple of good threads on 7A's if you use the search function.
Postby Crucible » Sat Sep 08, 2007 3:36 pm
has anybody for that matter ever had an sc14 happening on a 4agze yet?, everyone seems to start the project but never complete it.
always wanted to know what sort of power that combo would produce with fuel system & ECU. nobody seems to get there or always have problems that limit its full potential.
Crucible
Real Life Mechanic
Postby bluemaumau » Sat Sep 08, 2007 4:23 pm
the dogleg on #1 you have to make to mount the sc14 makes me cry
Postby 20v_rollaboy » Sun Sep 09, 2007 11:08 am
Will let you know how the SC14 goes once my new vehicle is tuned. :D
20v_rollaboy
Postby ezy10s » Thu Sep 13, 2007 6:04 pm
[quote="rollaholic"]actually my understanding is that using 4a pistons will lower the compression considerably, because the 7a stock pistons are taller.
Its actuallly the opposite- the 7afe pistons sit 20thou down from the top of the bore. 4age/ze pistons sit level with the top of the bore
(zero deck height) so when installing 4age/ze pistons into a 7afe block the compresion actually rises.
Member #244
ezy10s
Postby rollaholic » Thu Sep 13, 2007 9:48 pm
interesting, guess i mis-read something while reading that thread. whats the fix then? bigger headgasket?
nah
Postby ezy10s » Thu Sep 13, 2007 10:06 pm
running 8.0-1 pistons in 7afe block with any of the 16v heads the compression will aprox 8.5:1.
or the 8.9-1 pistons in same configuration will be about 9.4:1
will be a neat setup either way
Member #244
ezy10s
