info for getting certed
Postby JamesM » Fri Sep 07, 2007 12:12 pm
Just some info people looking at getting their cars certed.. this was on my ae86
(I am bored at work)
I took my car to Neil Fraser on the shore, I would recommend him, he is really into what he does and generally very helpful.
The following things he picked up on and I had to change/add:
• Do not remove the front dash – I have and had to either reinstall it or make a dash with some padding on the passenger side only.
• If you make adjustable arms such as adjustable panhard rod do not just weld a nut onto the end of the bar. Instead use threaded lugs which can be welded and then also welded again by drilling a small hole on each side of the tube.
• If you have significantly increased the power of the car (I don’t know if there is a significant figure.. but mine is turbo) you have to install a driveshaft safety loop that is positioned just behind the front universal joint. This is so that if you break the front uni then the driveshaft will not fly down into the ground and do whatever.. (you will still need to do this even if you have upgraded the uni joints and tube… even in my case where I used hilux joints which are twice the size of ae86 items).
• If you use fiberglass doors which have nothing in them.. (and hence flex like a mother). You will need to install a 25mm tube that basically goes from the catch to the hinge. This is to stop the door popping out or pulling apart in a crash. Kinda goes against the whole lightening thing…
• If you don’t have door cards and have sharp edges on fiberglass you need to put rubber lining around the edges.
• Make sure you use locknuts or spring and flat washers on all suspension parts.
• The speedo needs to be within 10%. Mine wasn’t and I took it to Auckland speedo services which cost 119$ to get recalibrated.
Taking it back on Monday and then will be all kapai
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby GTCRSHR » Fri Sep 07, 2007 1:32 pm
Neil Fraser is definatly the man to go to, very helpfull,
i had my corolla certified with him, he gave me a list of things that i needed to do, i did them, he passed them,
Nothing to see here ...
GTCRSHR
Postby crazed_silvertop » Fri Sep 07, 2007 1:43 pm
Just a quick question for you guys.. how much does he charge to have a cert put on?
The numpty I bought my MR2 off didn't cert the silver-top.
Also... contact details?
'89 MR2 AW11 - Silvertop..... fun :)
crazed_silvertop
Postby GTCRSHR » Fri Sep 07, 2007 2:23 pm
0800 4 CERTZ or 0800 423 789
Mob: 0274 956 286
mine was around the 400-450 mark
GTCRSHR
Postby rwd_mayhem » Fri Sep 07, 2007 4:59 pm
something else to add to the list,
make sure you don't lose the rubber blanking grommets from your firewall, i failed on this. because if theres a fire in the engine bay they are supposed to stop it from going into the car.
we got it good in chch, only $350
current: 1975 Valiant Regel
rwd_mayhem
Postby no_8wire » Fri Sep 07, 2007 6:33 pm
Price goes up as list of things they need to check gets bigger...
I think for to 3 mods its 350 standard...
no_8wire
Postby d1 mule » Fri Sep 07, 2007 6:58 pm
no_8wire wrote:Price goes up as list of things they need to check gets bigger...
nope. i had shitloads sone to me ae85 and was still $350 eg suspension, enging, box, wheels, RCAs etc etc . the price goes up on what modifications hve been done eg. cutting and welding of suspension parts or chassis will be more expensive not weather tou get your steering wheel mags and seats etc its different levels of modification not quantity of mods, well thats how it seems to work down here anyways.
d1 mule
Postby Mr Revhead » Fri Sep 07, 2007 8:31 pm
afaik they can charge what they like.
first thing to remember, is talk to them FIRST.
Postby Zak » Fri Sep 07, 2007 8:37 pm
Mine was done for about $480 or some thing by Neil, but the list of mods to my car is pages long.
About the only thing left unmodified is the passanger seat :lol:
Zak
Postby Mr Revhead » Fri Sep 07, 2007 8:40 pm
and when you get the plate.... make sure its stamped right....
got mine today.... missing the adjustable arms :evil:
Postby Zak » Fri Sep 07, 2007 8:44 pm
yeah, mine is missing all most every thing, you just have to keep the paper work for it all.
Zak
Postby Mr Revhead » Fri Sep 07, 2007 8:47 pm
what paper work? :roll: didnt get any of that either.
Postby Zak » Fri Sep 07, 2007 9:07 pm
All the papers signed by your certifier, saying what has been checked, what has been send of and tested and what not. It's just a copy of what they send to LTSA that the make your plate from. It has all the little bits that they leave of for some reason.
Zak
Postby JamesM » Fri Sep 07, 2007 10:51 pm
weird.. i paid 420 with neil..and he did my authority card at same time.. and my list of modifications is longer than zaks.
as far i know they can charge whatever they like..
yea i will make sure i get some sort of paperwork that lists absolutly everythign... just incase it gets missed off plate... and surely they wouldnt be able to fit everything on th eplate anyway..
Team Megasquirt
1984 AE86
JamesM
Postby Zak » Fri Sep 07, 2007 11:10 pm
Thats a damn good effort if you've got more mods than mine 8)
There isn't enought space for things like frontal impact, hand brakes, bonnet vents, couldn't even fit my diff on the plate :?
Infact the whole plate system is sort of a waste of time, surely they could just put a date of inspection, vin and what ever, and just put the mods on there database or what ever.
Zak
Postby Rick » Sat Sep 08, 2007 10:22 am
Zak have you got a driveshaft safety loop on your car?
Postby Zak » Sat Sep 08, 2007 7:57 pm
Not that i'm aware of, but my shaft was done by drive-in, so that could be why it wasn't needed?
Zak
Postby bluemaumau » Sat Sep 08, 2007 8:46 pm
apperantly, they leave most of the info of the plate but leave it in the computer system.
mate had a cert plate for engine, went and got another cert for adjusties , they told him that theyd just put it in the system. '
semi convientient but a pain for wofs and cops
Postby Zak » Sat Sep 08, 2007 8:51 pm
Yeah, wofs are worse with a cert than with out, they check every little thing against the plate.
Better with the cops though. The just check its there, then it's all sweet.
Zak
Postby Mr Revhead » Sun Sep 09, 2007 11:40 am
yeah he missed off the adjutable arms.
i want them on the plate as they are a lot easier to spot than a few things that are on the plate so im more likely to have issues with them.
its not as if theres no room fior them.
hes done a few things i was suprised at.
mentioned my 3mm spacers and the height on the plate. even though its not really low at all, and isnt adjustable for height.
