Hilux/Hiace diff ratios
Postby larryex » Tue Sep 11, 2007 7:34 pm
Does anyone know the highest diff ratio you can get factory in either a Hilux or Hiace diff head? anything higher than 4.3 to 1??
larryex
Postby evil_si » Tue Sep 11, 2007 8:00 pm
i think tony at steelie gears was saying theres a 4.7-1
evil_si
Postby larryex » Tue Sep 11, 2007 9:04 pm
Higher ratio... not lower!!!!!!
larryex
Postby Mr Revhead » Tue Sep 11, 2007 9:44 pm
i THINK some hiaces had a 3.9..... or maybe 4.1.
if i remember ill have a look tomorow
Postby strx7 » Tue Sep 11, 2007 11:46 pm
3.7, 3.9, 4.1, 4.3, 4.5, 4.875, 5.1 and 5.3 are the ratios they come in hiaces and hilux's
Postby larryex » Wed Sep 12, 2007 10:05 am
Ok thanks for that, I currently have a 4.3 and need to find a 3.9.
larryex
Postby strx7 » Wed Sep 12, 2007 2:22 pm
I assume thats in your JZ powered Hiace?
is it auto or manual?
My LN130 surf was originally a 4.55:1. I put the 2JZGE in it and then dropped down to a 4.1, but had been looking for a 3.9.
i'd be looking at a 3.7 as an option for a van
Postby larryex » Wed Sep 12, 2007 8:01 pm
Yes thats the one mate. Its auto and with the 4.3 its got good pick up and ideal for the towing its going to do, but its revving a tad high at 100k. Either a 3.9 or 3.7 would be ideal prob the 3.9 as its still going to be doing heavy towing as opposed to high speed cruising.
larryex
Postby strx7 » Wed Sep 12, 2007 8:42 pm
what revs are you sitting at at 100k's in overdrive?
Postby larryex » Thu Sep 13, 2007 6:36 pm
Around 2900 - 3000. bit high for a six. 2300-2400 would be good.
larryex
Postby strx7 » Fri Sep 14, 2007 9:53 am
if you're currently pulling 2900 rpm at 100kph, the overdrive 'gear ratio' would be 0.85:1
which means a 3.7:1 diff would see you at 2500rpm
3.5:1 would see you at a shave under 2400rpm.
for towing all the time 3.7:1 would be a MINT ratio.
a 3.9:1 would see you a shave under 2600rpm
Postby larryex » Fri Sep 14, 2007 7:27 pm
Cheers thanks for the tip. Ill pretty much use whatever one of the two I find first.
larryex
Users browsing this forum: Bing [Bot] and 25 guests
