Mr Revhead wrote:ae86 rotors are cheap...
then again so are all toyota rotors.
if your wanting to up grade then id look into what else can bolt to the hub and look at custom brackets for some skyline calipers.
or if the strock ae86 rotors are ok get some of those and fit a caliper thats easier to obtain
NZ_AE86 wrote:early 626 disc is one easy option, I can get the part No. if you like. They need redrilling but once mounted you can use a flat plate for your brake bracket.
ke25sr wrote:NZ_AE86 wrote:early 626 disc is one easy option, I can get the part No. if you like. They need redrilling but once mounted you can use a flat plate for your brake bracket.
Would defiantly like the part number. Are these Vented?
Have you done this? If you have what caliper was used?
ollieboy wrote:How cheap is cheap for brake rotors?
NZ_AE86 wrote:ke25sr wrote:NZ_AE86 wrote:early 626 disc is one easy option, I can get the part No. if you like. They need redrilling but once mounted you can use a flat plate for your brake bracket.
RX7 4pot, series 4/5/6 and yes they are vented. I have done this conversion several times. I will E-mail you the part no. and some pics.
ke25sr wrote:Trls250s wrote:how did you pay for the discs?
with cash.
matt dunn wrote:ke25sr wrote:Trls250s wrote:how did you pay for the discs?
with cash.
LOL,
I presume he meant how much, not just how.
