I need someone to do the welding for me, happy to pay either cash or beers for time and materials, depending on your preference
Please PM me with any details if you can help.
Thanks!
sergei wrote:You don't need to weld the seat belt mounts!!!
I have passed 4 times by different VINZ inspector on my car without rear seats.
I specifically inquired with LTSA to see if I need to do something about missing seat, response I got stated "as long as there are no seat belts mounted it is completely fine". Nothing about welding holes.
Dear Certed,
What's the deal with stripped out interiors? I have pulled all the carpet out of my Honda Civic SiR as well as the rear seats and all the plastic trim in the back and the boot. All I've got left is the two front seats and seatbelts, the dash and centre console etc... Now the problem is, I went for a WoF and was failed. They said because it had no interior that it was a race car and I'd have to take it someone else. I can't see what this has to do with safety, as the only thing different up the front of the car is no carpet, everything else is standard? Is there anything I can do, or will I have to put it all back in? Any help you could give me would be greatly appreciated.
Thanks, Martin.
Hi Martin,
I don't know why they refused to do your WoF inspection but they may have felt you'd increased the risk of occupant injury in a crash by removal of the trim bits. There's no problem with saving weight but be sure not to remove any of the interior trim or padding around the dashboard or the front seats like door panels or pillar covering, where sharp edges might be exposed. Assuming that's all OK and there are no sharp nasty bits, the only remaining issue is the rear seat removal.
As removal of seats falls within the definition of 'modifications' to a vehicle, then the section of the Vehicle Inspection Requirements Manual (VIRM) that lists 'Modifications that do not require LVV certification' has to be checked. That says that LVV certification is not required where the only modification is the removal of seats and/or seatbelt anchorages, however a class change and a new load rating may be required in some cases. If your vehicle was a van, seat removal might affect the class of vehicle, but as yours is a car, you may remove rear seats, and even the passenger seat without LVV certification. You should point out to the WoF issuer that they will find this on page 7-1-2 of the VIRM.
Good luck!
Old Hoon
