Quick turbo mounting question
Postby TRD_ZERO » Fri Oct 05, 2007 4:33 pm
Ive had a look on here and want to know why most of the 4age fwd guys mount their turbo so that the compressor side is on the drivers side? Is there any reason why i cant mount my turbo so that the compressor side is on the passanger side. What i mean is use a evo 4 and up turbo instead of a evo1-3 turbo. Is there any particular reason most of you run them evo1-3 style. Hope you can understand what im trying to get at.
TRD_ZERO
Postby IH8TEC » Fri Oct 05, 2007 5:04 pm
shorter intercooler piping if compressor is on drivers side.
actiondan used to make alot where the comp was on the passengers side and also able to retain aircon etc. and depends how tight the exhaust will be to the x-member
if your getting a custom manifold done, just put it exactly where you want :) there are pro's and cons of each that will determine how other things are done. if you mount the comp on the drivers side, there is generally not enough room for std oil filter (with bigger turbos)
also think about the return, you can only mount a turbo so high with the compressor on the drivers side. just make sure you can get the filter piping on, but also have enough height for return, (not so much of an issue with compressor on other side)
umm hope that helps.
Postby TRD_ZERO » Fri Oct 05, 2007 5:13 pm
Yeah that is the kinda info i wanted i want the comp side on the passenger side so i can have my air filter where the battery sits. Im wanting to keep the aircon and make a airbox which i cant see happening if the comp is on the drivers side. My biggest issue now that i think of it would be intercooler piping from turbo intercooler but im sure i can get around that somehow.
TRD_ZERO
Postby flygt4 » Fri Oct 05, 2007 5:16 pm
mines on passenger side. retains standard oil filter , although it requires removal of turbo downpipe to remove it. my airfilter sits where the battery tray used to be.
theres also a lot less stuff on passenger side, if i removed my intake i can stand in the engine bay between radiator and gearbox.
flygt4
Postby TRD_ZERO » Fri Oct 05, 2007 5:40 pm
Did you have any trouble clearing the crossmember with anything. Any issues mounting the external. Any issues at all? Id really appreciate some pics if you are able to post them up it will give be a better idea of what my next step will be.
TRD_ZERO
Postby escortman » Fri Oct 05, 2007 6:29 pm
i mounted my tdo5 so compressor on drives side but im running remote oil filter and ditched a/c and powersteer so have heaps of room haha
4x4 toyota blizzard offroader
escortman
Postby evil_si » Mon Oct 08, 2007 6:44 am
ive made manifolds to suit both,
evo 4 on turbos are generally more expensive, hence less people using them, and a bit more cost in making manifold to suit twin scroll.
drivers side is my preferred direction, shorter intercooler piping, doesnt need to pass over turbo or exhaust,
no need for airbox if airfilter is under front guard,
powersteering doesnt generally become an issue, if building a decent setup most people i met were ditching their a/c.
evil_si
Postby flygt4 » Mon Oct 08, 2007 5:35 pm
im sure the piping is exactly the same for either side as the compressor still points down in roughly the same place.
ive yet to see a 4agte that retains the aircon
no issue clearing crossmember
only issue to consider is clearance from radiator, but that is relevant to mounting either way. ive seen civic half radiators used often.
wastegate tees off to drivers side and runs down under next to exhaust.
there is only one spot where exhaust and i/c piping gets close and thats really only because my piping is a poor fit.
a quick paint picture of the plumbing
flygt4
Postby IH8TEC » Mon Oct 08, 2007 5:41 pm
flygt4 wrote:Image
thats beautiful :lol:
Postby flygt4 » Mon Oct 08, 2007 5:43 pm
hahaha shhh ive had about 3 people ask me how you plumb the piping for a passenger mount intake through PM already, thought id try and put the info out there :lol:
its about as tidy as my setup too :wink:
flygt4
Postby Lloyd » Mon Oct 08, 2007 5:57 pm
Or feed the piping the other way if you want to do it the other way. Compressor on the passengers side, air filter where the battery was.
Postby flygt4 » Mon Oct 08, 2007 6:01 pm
ooh good idea i like that very much.
flygt4
Postby escortman » Mon Oct 08, 2007 6:25 pm
Shot with EX-Z60 at 2007-09-23
Shot with EX-Z60 at 2007-09-18
mine fits with ae92 radiator
escortman
Postby Lloyd » Mon Oct 08, 2007 7:10 pm
I think my one was an ActionDan job, no need to relocate the filter or anything
Postby 20v_rollaboy » Mon Oct 08, 2007 9:21 pm
Maybe a bit off topic, but has anyone ever high-mounted a turbo on a 4age? And particular reasons why not?
20v_rollaboy
Postby IH8TEC » Mon Oct 08, 2007 9:28 pm
main reason is space with high mounting.
Postby escortman » Mon Oct 08, 2007 10:33 pm
yeh with mine i can fit a filter but the sandwich plate for oil cooler puts it out 2far
escortman
