-solved-
-solved-
Postby Zyros » Fri Oct 12, 2007 11:20 pm
problem solved.
Zyros
Postby Zyros » Sat Oct 13, 2007 10:36 am
bump, urgent.
Zyros
Re: HELP<> Lost Main End Caps for crank
Postby Toymad » Sat Oct 13, 2007 11:00 am
Zyros wrote:Block's being honed, and surfaced etc.. can i get new end caps?? Or would i have to get a whole different block with the end caps and get that block recon.
If you were getting block work, normally you send the caps in with it. Have you checked with the reconditioner or do you know you did not send them in?
If I were getting a set of main caps from anywhere, I'd be getting the caps fitted to the block and then line bored. It makes sure that the caps are the right size and shape.
Might pay to mention the type of engine for those who don't know what you are after.
David
Toymad
Postby Mr Revhead » Sat Oct 13, 2007 1:56 pm
yes if you loose the caps
you will need to get some 2nd hand ones and get it lined bored
Users browsing this forum: No registered users and 26 guests
