hi,
can someone tell me what colour is the 12volt batt wire from the ignition key switch.
thanks
tgb.mr2 wrote:Real specific there buddy.
Get a multimeter or a testlight and find an ignition only 12V+
usually the Cig lighter is the easiest for me.
LEV_101 wrote:tgb.mr2 wrote:Real specific there buddy.
trying to wire up my turbo timer.
as for using a multimeter. i touch the wire with red lead and the black lead onto the ground chassis ?
thanks
Defective wrote:LEV_101 wrote:tgb.mr2 wrote:Real specific there buddy.
thanks
hmm, not really a job you wanna attempt if your not real flash with electricals... turbo timers can cause some weird gremlins when wired up incorrectly...
tgb.mr2 wrote:Got to learn how to do these things somehow, giving it a go is the best way to learn![]()
set the multimeter to the correct voltage range (20V) and yep black to earth.
MRDRFT wrote:why do u need a turbo timer?if the car needed one it would come factory.i havent ever used one and i have never had a problem.waste of petrol i think.
