Cams and power.
Postby ollieboy » Sun Oct 21, 2007 9:12 pm
I was thinking more about price :D
ollieboy
Postby strx7 » Sun Oct 21, 2007 9:52 pm
where abouts are you? I think you'd be suprised freight costs
Postby RS13 » Sun Oct 21, 2007 9:59 pm
Adamal wrote:Just get a Rotax engine. They're designed for high altitude and low density air.
Seconded. Trust me, this may end up being the easiest option. Adapting any automotive gear to aviation involves a lengthly and costly certification process, I'm not 100% sure about regulations for microlights but I'd imagine them to be similar for light aircraft.
Rotax engines are reliable, small and lightweight, however everything in aviation costs considerably more due to the safety factor inbuilt into parts.. and you won't have to mess around with reduction gearing or anything to get the rpm you want.
Redmist wrote: A VW H engine is where you want to head. They have been used in aircraft applications for years and have aviation kits available for them.
Yup, I would look into these as well, I've seen these around for years, we rebuild them at course (I'm a trainee aircraft engineer).
RS13
Postby RedMist » Mon Oct 22, 2007 9:57 am
I'd be tempted to go TRS Microturbo... but you probably want to keep it away from anything flamable!
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby ChaosAD » Tue Oct 23, 2007 8:21 pm
ransack a hyabusa SP? for its engine :twisted:
ChaosAD
Postby fangsport » Thu Oct 25, 2007 7:19 pm
Ollie, this better not be your handy work???
http://nz.news.yahoo.com/071025/3/264z.html
fangsport
Postby ollieboy » Thu Oct 25, 2007 8:20 pm
Haha :lol: Nah, mines still just some pieces of metal spot welded on a shed floor.
I have found, building a microlight is exactly the same as building the model glider's I used to build only on a much larger scale. It's not really surprising they crash a lot. Theres not much regulations on single seaters and they are very lightweight and flimsy. :?
ollieboy
