ignition upgrades
ignition upgrades
Postby MR2SIK » Wed Oct 31, 2007 4:56 pm
Was just wondering if anyone could shed some light on upgrading ignition components, Ive had a bit of a look around but its all rather gobbledee goop to me :lol:
It appears my standard stuff is only just coping, so was thinking of getting something a bit stronger/reliable. Especially with further Hp gains in the next 12 months.
any help/guidance to help would be great
Cheers.
Sean.
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby ChaosAD » Wed Oct 31, 2007 5:28 pm
Do you have an aftermarket ecu? if so you could go wasted spark like the 4agze and use evo coils
ChaosAD
Postby flygt4 » Wed Oct 31, 2007 5:39 pm
in what way is your ignition system not coping? are you getting misfiring at high rpm etc?
my stock silvertop single coil distributor setup is still comfortable at the same power level you're at. thats with standard 20v dizzy,20v coil, 20v ignitor and 20v leads.
I do run quite cold plugs tho, NGK 8's i think
that said i have replaced in the last 12 months, the plugs,distributor,rotor, dizzy cap, leads, coil and ignitor so its all pretty fresh.
may pay to try a freshened up standard system first and se how it goes.
flygt4
Postby MR2SIK » Wed Oct 31, 2007 7:28 pm
yea high revvings a no go at the moment, Everything except the igniter is less than 4000kms old so on the look out to replace that too.
Running a linkplus now,
*wonders if my little brother will notice the coils missing out of his evo :lol: *
MR2SIK
Postby matt dunn » Wed Oct 31, 2007 8:42 pm
Go for the EVO wasted mspark setup,
really is the best option for $ spent.
I have just converted to Evo coil setup from single coil on my race car.
Matt
Postby strx7 » Wed Oct 31, 2007 9:00 pm
doesn't have to be out of an evo. all the twin cam galants run the same coil packs, dime a dozen at any dismantler who's done galants
Postby matt dunn » Wed Oct 31, 2007 11:09 pm
strx7 wrote:doesn't have to be out of an evo. all the twin cam galants run the same coil packs, dime a dozen at any dismantler who's done galants
even most of the V6 mitsi stuff uses the same coils, just 3 instead of 2.
I have the odd one where both the coils are moulded together so it is all one piece, but that is the uncommon galant type.
Postby strx7 » Thu Nov 01, 2007 10:07 am
yip cause i'm running a 6G72 daimante pack on the 2JZ in my surf
Postby Santa'sBoostinSleigh » Thu Nov 01, 2007 10:15 am
so 6a12tt v6 vr4 coil packs will do the job?
ive got a set of these and am nearly ready to do my N/A 20v LEM G3 setup
or is there a better/easier option
(sorry to hijack the thread)
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby mr30%jr » Thu Nov 01, 2007 12:20 pm
so dont even need expensive mitsi vr4 ones i have some mitsi ones of some crappy cheap ass mitsi i was given like 4 sets
mr30%jr
Postby try_hard » Thu Nov 01, 2007 12:33 pm
yea i brought some evo coil packs & igniter from a member of here
AE92 Trueno Sprinter 4AGZE
try_hard
Postby AceSniper » Thu Nov 01, 2007 1:33 pm
also some hyundai sonata's have 4g63's and the bracket has everything you need... 2 dual post coils, ignitor and tacho interface
and "evo" coils an ignitors are the same as any other mitsi with wasted spark
im using n/a mitsi coils and a vr4(v6) ignitor... just not using the 3rd channel
AceSniper
Postby slighty_sykotic » Thu Nov 01, 2007 3:13 pm
mr30%jr wrote:so dont even need expensive mitsi vr4 ones i have some mitsi ones of some crappy cheap buttocks mitsi i was given like 4 sets
Want to sell a set?
slighty_sykotic
Postby ChaosAD » Thu Nov 01, 2007 5:33 pm
Are there any leads available? or do you need custom ones made up?
ChaosAD
Postby QikStarlie » Thu Nov 01, 2007 9:31 pm
just use a stanadrd type lead. go to supercheap and grab some bosch leads for $6 each at the length you require.
QikStarlie
Users browsing this forum: Bing [Bot] and 4 guests
