pop noise wen changin the song?
Postby 5afe_Toy » Fri Nov 02, 2007 8:21 am
hey guys havn problems wit my sounds , everytime i press a button on my head unit or turn it on and off it makes a short basy pop through the speakers i think it culd b earthing out somewere or it the headunit im not to sure if anyone culd help it would b apreciated :D
5afe_Toy
Postby Rumad » Tue Nov 06, 2007 8:26 pm
what brand of head unit and amp have you got?
Rumad
Postby 5afe_Toy » Wed Nov 07, 2007 4:12 pm
panisonic headunit and a fusion amp, it was working all gud till i put the subs in a differ box and amp in a difer place so i duna why it doing it , was working fine before that
5afe_Toy
Postby DeeCee » Wed Nov 07, 2007 4:35 pm
generally pops are a sign of:
a) bad equipment
b) bad terminations (ie ground or other cabling)
c) interference picked up somewhere
if you have moved the sub and amp, you may have knocked something, so recheck all your cabling and terminations to ensure you haven't knocked anything loose.
GT Four Adovansu
DeeCee
Postby Matty104 » Wed Nov 07, 2007 9:27 pm
mine did the same when i got all my gear back after it got riped off, turnd out one of the circut boards inside the amp were cracked and broken, had to get them replaced, cost me about 140 bucks in then end
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby 5afe_Toy » Mon Nov 12, 2007 10:08 pm
oh ok well i checked all the wiring and wen i unplug the rca cords so the amps nt going through my headunit there is no noise but az i do plug it in thers a pop when i press butons on the head unit so i think it could b the amp but i guess il have to try a differ amp so ino it is that , it just trial and error that il have to go by , thanks for your replys :D will let you know if i sought the problem or not
5afe_Toy
Postby 5afe_Toy » Wed Nov 21, 2007 6:53 pm
well ive tryd differnt amps n rewired the amp wires nd no difference so i think i needa re-wire my head unit or buy anotha 1
5afe_Toy
Postby pjay » Wed Nov 21, 2007 7:32 pm
voltage spike ftl
pjay
Postby 5afe_Toy » Thu Nov 22, 2007 6:21 pm
pjay wrote:voltage spike ftl
what does that mean bud?? can i fix it at all ?
5afe_Toy
Postby pjay » Thu Nov 22, 2007 7:16 pm
make sure your ground cables are good. ie: sanded down to bare metal on the chassis, and the right thickness.
Reground your car battery as well, hell, just re ground everything!!
*waits for deecee*
pjay
Postby 5afe_Toy » Thu Nov 22, 2007 10:10 pm
i regrounded n rewired all the amp gear but not the battery ground wire, but il try this 2mrw cheers
5afe_Toy
Users browsing this forum: No registered users and 32 guests
