Custom sway bar ??????
Postby 3T-Rona » Wed Nov 07, 2007 7:08 am
when running a 4age carb'd do pple usually change the dizzy to one with vaccum advance? or just use the OEM one?
3T-Rona
Postby NZ_AE86 » Wed Nov 07, 2007 7:12 am
Several options, you can mod a 4k one or 626 or many others.
Best option is to keep the efi!
If you must put carbs on then leave the factory Dizzy and all sensors/wiring ecu and the computer will control your advance. (you don't need all the sensors but if you just leave then all there you can return it to EFI)
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby 3T-Rona » Wed Nov 07, 2007 5:46 pm
sounds good, ill change this Post since it has served its purpose.
Where To get a custom sway bar made/from???? anyone?
3T-Rona
Postby postfach » Wed Nov 07, 2007 6:12 pm
can you get a whiteline one?
although....i've been waiting 15 weeks for mine to show....
postfach
Postby Adoom » Wed Nov 07, 2007 6:32 pm
3T-Rona wrote:sounds good, ill change this Post since it has served its purpose.
Try NZ Spring works(formerly Jaguar Springs) in Lower Hutt. A swaybar is only an unwound spring anyway.
They might not be able to fit a swaybar in their kiln though. Try them anyway they might know who can do it.
http://www.nzspringworks.co.nz/index.htm
Adoom
Postby ke25sr » Wed Nov 07, 2007 9:04 pm
Im about to make my own. bought spring steel from Brown & Cope. bend it to shape. Flaten the ends for rose links. then get it hardened.
steel 17mm 2 meters $55.00
to harden it cost $30.00
The links i haven't priced yet.
ke25sr
Postby Bling » Wed Nov 07, 2007 9:32 pm
did ya just bend it over ya knee?
out of serious interest tho, how did ya bend it? :lol:
Postby ke25sr » Wed Nov 07, 2007 9:51 pm
heat and bend with a pipe i reckon i only just got the steel. haven't started bending yet.
Ill just follow the shape of the original bar
ke25sr
