soarer auto top speed
Postby avinesh » Sun Nov 25, 2007 9:00 pm
any one know wat the auto 1jzgte soarers top out at when delimited, searched on the net but couldnt find any results, cheers
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
avinesh
Postby postfach » Sun Nov 25, 2007 9:55 pm
depends how much power you have, unless you want to know the theoretical top speed, in which case you can find a calculator on the net (google top speed calculator) and then input your diff ratio, rolling diameter of your driving wheels, final gear ratio and rev limit.
postfach
Postby Mr.Phreak » Sun Nov 25, 2007 11:16 pm
Most people don't know as the dash stops displaying above 180k :lol:
Either way, it's probably a lot quicker than you'll want to be going on anything but an airstrip
Mr.Phreak
Postby Bling » Mon Nov 26, 2007 12:23 am
another way to work out theoretical is to put it into top gear and measure the check speed at certain rpm the multiply it to suit your redline.
at least i think that works...
Postby MNT » Mon Nov 26, 2007 8:36 am
BZG|Bling wrote:another way to work out theoretical is to put it into top gear and measure the check speed at certain rpm the multiply it to suit your redline.
I "think" that only works if your top gear is 1:1 or something. Otherwise it is a little bit out.
MNT
Postby barryogen » Mon Nov 26, 2007 9:19 am
It'll work... but it'll only give you top speed assuming little to no wind resistance.
If I used that, in theory my corolla could do... 286.2km/h... when according to the factory, and some testing, it is actually closer to 220km/h@ ~5000RPM(from memory) before it runs out of torque, well, hit the invisible wall of wind resistance.
100kmh/2900
286.2kmh/8300
barryogen
2ZZ Guru in training
Postby Si » Mon Nov 26, 2007 10:52 pm
My supras theoretical max speed was something like 300 kph 8)
Current: , '96 SubaruImpreza
Si
Re: soarer auto top speed
Postby 2jayzgte » Tue Nov 27, 2007 7:45 am
avinesh wrote:any one know wat the auto 1jzgte soarers top out at when delimited, searched on the net but couldnt find any results, cheers
If you no what your final drive or diff ratio is that would help alot???
I no the TT JZA 80 Supra Auto's run a 3.77 diff which gives it a top speed delimited in the 265-275 KPH area.So if you can find out what sought of diff ratio your running then that'll give you a better guide.
2jayzgte
Postby Lith » Tue Nov 27, 2007 9:13 am
Most of the high end Japanese cars seem geared for ~270-280kph max.
2007 Mazdaspeed Axela
Lith
Users browsing this forum: Bing [Bot] and 26 guests
