soarer auto top speed
Post Reply
avinesh
Post by avinesh »
any one know wat the auto 1jzgte soarers top out at when delimited, searched on the net but couldnt find any results, cheers
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
postfach
Post by postfach »
depends how much power you have, unless you want to know the theoretical top speed, in which case you can find a calculator on the net (google top speed calculator) and then input your diff ratio, rolling diameter of your driving wheels, final gear ratio and rev limit.
Mr.Phreak
Contact:
Post by Mr.Phreak »
Most people don't know as the dash stops displaying above 180k :lol:
Either way, it's probably a lot quicker than you'll want to be going on anything but an airstrip
Contact:
Post by Bling »
another way to work out theoretical is to put it into top gear and measure the check speed at certain rpm the multiply it to suit your redline.
at least i think that works...
MNT
Post by MNT »
BZG|Bling wrote:another way to work out theoretical is to put it into top gear and measure the check speed at certain rpm the multiply it to suit your redline.
I "think" that only works if your top gear is 1:1 or something. Otherwise it is a little bit out.
barryogen
2ZZ Guru in training
Contact:
Post by barryogen »
It'll work... but it'll only give you top speed assuming little to no wind resistance.
If I used that, in theory my corolla could do... 286.2km/h... when according to the factory, and some testing, it is actually closer to 220km/h@ ~5000RPM(from memory) before it runs out of torque, well, hit the invisible wall of wind resistance.
100kmh/2900
286.2kmh/8300
Si
Contact:
Post by Si »
My supras theoretical max speed was something like 300 kph 8)
Current: , '96 SubaruImpreza
2jayzgte
Re: soarer auto top speed
Post by 2jayzgte »
avinesh wrote:any one know wat the auto 1jzgte soarers top out at when delimited, searched on the net but couldnt find any results, cheers
If you no what your final drive or diff ratio is that would help alot???
I no the TT JZA 80 Supra Auto's run a 3.77 diff which gives it a top speed delimited in the 265-275 KPH area.So if you can find out what sought of diff ratio your running then that'll give you a better guide.
Lith
Post by Lith »
Most of the high end Japanese cars seem geared for ~270-280kph max.
2007 Mazdaspeed Axela
Post Reply
