NZ GTi Questions
NZ GTi Questions
Postby BROCKZILA » Fri Nov 30, 2007 6:02 pm
Got a NZ new Corolla Gti 1990 manual just need a few answers sorry if this is already posted elsewhere but I have trouble navigating forums :cry:
1. How fast should it go? Around Puke track I couldn't get more than 180kmh out of it, my EP71 si Starlet did 170kmh I was hoping for 190 am I being optimistic?
2. How many kms do you guys get out of a full tank of gas?
3. How do I make it go faster? It has extractors and exhaust and pod filter (which I want to get rid off and replace with an airbox.
4. It has red lettering on top and t-vis what does this mean? Is it a good model or should I flag it and buy a 20v AE101?
thanks in advance
Daimin
BROCKZILA
Postby rollaholic » Fri Nov 30, 2007 6:52 pm
depends what you want it for. it will be limited to 180km/hr, hence your inability to hit 190.
the engine you have is commonly referred to as a bigport, and its generally agreed that the later model "smallport" 4AGE was the best of the 16V breed.
you want it to go faster, go turbo! seriously.
tvis = "toyota variable intake system".
you'll see the intake manifold has 8 inlet runners, basically tvis blocks off four of those runners at low revs to maintain air velocity, as with the excessively large inlet ports on the bigport they are extremely sluggish otherwise. once the revs hit 4200 or so the butterflys open and all inlet runners feed their respective cylinders. this setup was done away with in the smallport, and though the smallport is a better engine the bigport has a nice sound once the tvis butterflys open and gives you a kick in the back too (im sure you've noticed this) which makes it feel faster than it is :D
edit - engine swaps are pretty easy throughout the 4AGE range, so you dont need to replace the entire car if you decide you dont like the engine - just do an engine conversion ;)
Postby Quirky » Fri Nov 30, 2007 7:17 pm
When i had my Corolla, it was the same year, but it had the smallport . I thought all Corolla FX/GTi had the smallport after 1989.
AND, to answer your question, i got approx 400-450km a tank.
AND 350km a tank on a "good day".
Hello There
Quirky
Postby BROCKZILA » Fri Nov 30, 2007 7:23 pm
Thanks heaps guys for your replies I didn't expect them so quickly.
It didn't feel like a limiter e.g fuel cut etc
BROCKZILA
Postby Mr Revhead » Fri Nov 30, 2007 8:12 pm
no, it wont be speed cut
the 180k limit was a JDM thing from around 92 onwards
Postby rollaholic » Sun Dec 02, 2007 7:45 pm
ah yeah reading the OP correctly ftw
Postby pidge » Mon Dec 03, 2007 1:58 pm
Mr Revhead wrote:no, it wont be speed cut
AE101's have it - at least my GTZ does.
pidge
Postby Mr Revhead » Mon Dec 03, 2007 2:18 pm
and they started making 101s around 92 :wink:
last half of 91 to be exact
Postby rollaholic » Mon Dec 03, 2007 5:45 pm
he did say its NZ new also, which i believe are not limited - at least, my AE82 wasn't.
Postby Punter » Mon Dec 03, 2007 6:26 pm
1) Is that an indicated 180km/h on the back of puke?
My standard 20v shows approx 200, and i've been clocked with a laser at
173 just past the kink, so I think about 180 ~ 185 is my true top speed.
2) I get usually get 550km to a tank.
3) Do a search, it's covered everywhere, and I can't be bothered going into
detail here
4) IMO keep the 16v, with a bit of money in them they go quite well.
And the cheapest car is the one you already own.
I love deadlines. I like the whooshing sound they make as they fly by.
Punter
Postby BROCKZILA » Mon Dec 03, 2007 6:36 pm
Punter wrote:1) Is that an indicated 180km/h on the back of puke?
173 just past the kink, so I think about 180 ~ 185 is my true to speed.
detail here
Yeah indicated 180 from the kink all the way to the "100" marker.
True it is cheaper to do up something i already have have to talk the mrs into letting me take her BZ wagon around :)
BROCKZILA
Postby Punter » Mon Dec 03, 2007 6:56 pm
So you don't pick up any speed from the kink onward?
Can't say I've driven a Bigport around puke so that might be normal, but it doesn't seem right.
Punter
Postby BROCKZILA » Mon Dec 03, 2007 6:58 pm
Punter wrote:So you don't pick up any speed from the kink onward?
Yeah no pick up from the kink it has new plugs and fuel filter but need to get the timing checked
BROCKZILA
Postby FYADUP » Tue Dec 11, 2007 11:20 pm
Yer if its a genuine nz new corolla gti then it should have 240km speedo, and i got to 230km in mine before i dropped my sacks :D So no reason why you can't get there. As for going faster, depends if you want to stay NA, or go forged/motor transplant anf go turbo/supercharged.
R.I.P - 90 4AGTE GT-i Corolla Hatch [ROLYOU]
New 91' Corolla GT-i project! WATCH THIS SPACE
FYADUP
Postby BROCKZILA » Wed Dec 12, 2007 9:58 pm
Yup is NZ new got the 240 speedo, wind up windows, etc. 230!!! dam i'd be happy with 200 just want to stick it to some of the hondas on the straights dam their VTEC
BROCKZILA
